Take that alternator to autozone bud, on or off of the vehicle they can test the alternator and tell you if it's shot or not
25d9cf71-fff8-4b67-a8f5-28c80d5ea859_zps7d3fe7f6-90c4-4939-b709-43f0e5812212_zps
2018 Honda Civic Sport Hatchback (build in progress)
NVX Sound Deadener (Front Doors)
Stinger FAST Rings
Stock Electrical
SSA Evil 6.5's Front Speakers
Stock rear speakers
MB Quart ONX4.80 speaker amp
Rockford Fosgate T-1500bdcp
DC Level 4 12" D1 @ 2-ohm
Box In Design Stage
Stock Radio
My Build Log
I live in Cape Town South Africa buddy,,, but ill see where I can take it, thanks a mill
Oh ha, sorry man, didn't really look! Any parts store near you that would have a machine to test the alternator and regulator? I mentioned Autozone cause I work there part time
Stinger FAST Rings
Stock Electrical
Stock rear speakers
Box In Design Stage
Stock Radio
My Build Log
I found a blog forum on the issue, said the following :
What do you guys think? Voltage Regulator
  • Nearly every automobile alternator-generator unit is coupled with a voltage regulator, which determines the actual output of the alternator. The voltage regulator detects the charge level of the battery and can decrease the voltage output of the alternator once the battery is nearing full capacity. As a result, the voltage output from the alternator, as it produces electricity for the vehicle's battery, may drop once it has reached higher RPMs if the electrical load requirement is low.
Read more: Why Does an Alternator Drop Voltage When Sped Up? | eHow http://www.ehow.com/info_7791228_alternator-drop-voltage-sped-up.html#ixzz2W11n1YWx
Well... That's ehow... LOL
That might only be true if your alts is PCM controlled. But it shouldn't drop into battery voltage when revved.
  • 1 month later...
Problem sorted guys>Thanks ton the men who helped... and the Knowitalls
And the problem was? Good to know the fix...
Pioneer AVHX-5800BHS
Alt CES 200/270+
  • Who's Online   0 Members, 0 Anonymous, 1598 Guests (See full list)
