12volt_Trini Posted June 11, 2013 Report Posted June 11, 2013 Anybody uses db converter?....i would like to know some views... Vehicle: 2000 Toyota Corolla Limited S Head Unit: DEX 99rs pioneer Speakers Sub treble/High mid : 2 1.4 inch throat 2080 18 sound drivers neodyium with wave guide Tweeters: 2 Mtx dome, 4 APT eminence super tweeters Mid Range: 2 18Sound 6" 6ND410 NEO,2 18 Sound 10" 10NDA610 NEO Low Mid Range: 2 18 Sound 10 NMB420 Sub: 2 Z-12 V.3 D1 - Sundown Audio Amplifiers Sub treble/High Mid: MTX Audio TA5302 Thunder Tweeters: JL Audio e4300 4-Channel Mid range: MTX Audio TC3002 Mid range: MTX Audio TA7402 Thunder 7402 Low Mid Range: MTX Audio TA7402 Thunder 7402 Sub: MTX Thunder Elite 4001D Alternator: 220amp mechman Batteries: 3 D3100 XS Power
sprkn_ranger Posted June 11, 2013 Report Posted June 11, 2013 When you download a song from iTunes on an iPhone, what format is it and is it possible to get it as a wav instead?It's 128 kps AAC, and if you want wav., buy the physical CD and extract the wav. file from it, you'll get a 1411 kps file. If you want to run lossless on an apple product, then use Apple Lossless or the format .aiff. Oh ok I see. Is apple lossless good? And can I convert my 128kps file to apple lossless in iTunes? (On the computer, of course) Check out my build log! 4 Havocs in a blowthrough http://www.stevemeadedesigns.com/board/topic/187506-sprkn-rangers-blowthrough-build/
Omega5002 Posted June 11, 2013 Report Posted June 11, 2013 When you download a song from iTunes on an iPhone, what format is it and is it possible to get it as a wav instead?It's 128 kps AAC, and if you want wav., buy the physical CD and extract the wav. file from it, you'll get a 1411 kps file. If you want to run lossless on an apple product, then use Apple Lossless or the format .aiff. Oh ok I see. Is apple lossless good? And can I convert my 128kps file to apple lossless in iTunes? (On the computer, of course) Apple lossless is equal to Flac. You can but you won't gain anything cause it's already compressed and won't sound any better. 2003 Kia Sorento Team Subsonic LowsTeam Bassin' on a Budget2016 Rebuild Under Construction Best score: 150.2 at 40hz (3k, 2 Custom HDC3 15's) Usaci style(door open, in the kick)
sprkn_ranger Posted June 11, 2013 Report Posted June 11, 2013 Gotcha man, thanks Check out my build log! 4 Havocs in a blowthrough http://www.stevemeadedesigns.com/board/topic/187506-sprkn-rangers-blowthrough-build/
soundstream15 Posted June 11, 2013 Author Report Posted June 11, 2013 So I guess when you download music that's mp3 it's clipped? So like if I would pirate some CDs then there's a good chance they would be clipped?
Baydestrian Posted June 11, 2013 Report Posted June 11, 2013 LOL Itunes is not 128kbps AAC anymore, its 256kbps OT: It has been said plenty of times before....SOURCE DOES NOT FUCKING MATTER. You can pirate, buy Amazon, buy from Itunes, buy pressed CD. If the song was clipped during production then it will be clipped in any format. If its clean from production then it will be clean no matter what. On that note, worry more about your headunit and amp settings rather than the music clipping. A clipped signal before clipped music is where the true harm will come from. If your signal is clean then you can get away with some clipped music, just know if the song is clipped by using Windows Media Player and keep the volume lower. Unless a song distorts (i.e. Gucci Mane - Swing My Door, Cousin Fik - Shot a Brick) audibly then don't play it. I myself worry more about clipped sub bass than I do clipped kicks 2015 Mazda 6 JVF Customz 4.0 Proto 15>Wolfram W4500 @ .5ohm 2 Sundown Neo 6.5 + 2 CT Meso Tweeters (Front) x Kicker KS6.5 (Rear)>JL Audio VX400/4i NSB-AMG35 (front) / 40ah Lithium Headway (Rear) built by Erni Audio & Electrical
shogen Posted June 11, 2013 Report Posted June 11, 2013 been using it for years... best converter EVER!!!! it's only a converted as in trading formats... so you can't "increase" the quality just because you made an MP3 a WAV file or made a apple file a FLAC file .... or if you made a 128k MP3 into a 320K MP3 Anybody uses db converter?....i would like to know some views... Pioneer Premier P880PRS ll Front Stage: US Acoustics 4060 - Random speakers currently ll Sub Stage: Crescendo BC3500D - 15" Xcon sealed @ 3.28 cubes ll Electrical: - Kinetik HC1800(front) NEW***DieHard P-2(rear) beaker- I know this sounds like a lot of anime bullshit, but it is true.
