EXTERNAL REGULATOR QUESTION 3.5L H3 5CYL
So I installed a external voltage regulator, My question is how can i duplicate a connection for my pcm to read so i can clear my electrical system fail code?
https://photos.google.com/photo/AF1QipP7rjav9cD9UFdAYBJmz4M4LoNlF26ng1xhAf4Uhttps://photos.google.com/photo/AF1QipP7rjav9cD9UFdAYBJmz4M4LoNlF26ng1xhAf4U
2013 DODGE CHALLENGER R/T
SUNDOWN ZV4-18
CRESCENDO 3.5K
PIONEER AVIC 5300 NEX
ALPINE TYPE R 6.5S & 6X9'S
ROCKFORD FOSGATE 1.5" TWEETS
5 C&D TECH BATTS
You can't.
Ok any other options? maybe you could suggest an alternative
SUNDOWN ZV4-18
CRESCENDO 3.5K
5 C&D TECH BATTS
Run an internally regulated alternator?
06 Police TahoeHU- Pioneer 80prsAmp- Crossfire 8kSub- 4 15" Crossfire xs v2sWire- 1/0 Knu/AudiotechnixAlt- 3 Mechman SMD 340sBatts- 6 XS Power 3100s, 2400
Is it a separate dash indicator? You could unplug the bulb.
Or do some research into how the circuit works and what triggers the code. Then go from there. Maybe you need to put a resistor across some wires to act as a dummy load? Wire a read wire to the alt or something? Stuff like that is what you need to find out
You can't.
Get a mechanic to clear the code?
The light will keep coming on as long as his stock alt plug is disconnected.
You can't.
If you dont fix the problem that is setting the code, the check engine light will be right back on....
Daily Driver 1999 Kia Sephia
Kenwood DNX-893s
Audison Bit One Processor
2 Dat 4.125's
Sundown Audio SCV-6k
Hertz hsk-165xl's Mids running active        Focal V30 Series Tweeters running active
Sundown Sa-8 v1's in the doors
2 Sundown Zv5 12's
Lots of Hushmat
Big 3+ and 3 + & 3- runs of Trystar 2/0
2 Dc Power Engineering 320 HP Alts
2017 Comp Vehicle
2006 Toyota 4 Runner
Kenwood Excelon DNX-893s        Audison Bit One HD DSP
4 Sundown Sa 6.5v2 Component Sets
Focal Access 6.5 2 ways
Sundown Audio Sax-50.4        Sundown Audio Sax-100.4
2 Dc Power 370xp
Northstar agm27f
Northstar agm65
2 Northstar asmagm 480's
2 Dual 1 Sundown Nightshade v3 12's
2 Sundown SCV-7500's
All SMD Fuse Holders
Shitload Of Sundown 1/0
120 sq ft Second Skin Damp Pro
No, Its Not A Burp Truck!!!!
2016 Season 3rd place in Xtreme 1 At Finals
2016 Season 6th Place In Kaos 1 At Finals ( Blew The Subs Up In First Round Eliminations)
2 Kansas State Records Set In 2016 In Xtreme 1 And Kaos 1 In Midwest SPL
David said:
audio is a lifestyle, not a hobby
newls1
I cant read a tape to save my life... 1/2's are ok, but other marks confuse me
kingsuv
only men who cant read a tape, take it in the ass
kingsuv
you sir, get a pink hard hat on jobsites
Thank you, thats where I was going with this. i will try this and update you guys.
SUNDOWN ZV4-18
CRESCENDO 3.5K
5 C&D TECH BATTS
  • 1 month later...
You can't.
You can't.
Its been a while, But I figured out how to fix and has been good for 7 full days, I waited to post till I was sure. I took a positive lead from a switched power ran that to a 12v light bulb (turn signal) took negative from bulb and wired to the gray field wire that goes to the ecm....works great!!!!
SUNDOWN ZV4-18
CRESCENDO 3.5K
5 C&D TECH BATTS
  • Who's Online   0 Members, 0 Anonymous, 1366 Guests (See full list)
