Even More Electrical Problems...*pictures*
I actually think it would take more heat to start a fire on wood then plastic. But I couldnt be rocking a piece of wood in my ride lol.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
wrong thread hate IE
Edited by n8ball2013
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
and the heat wouldve kept rising if he didnt shut it off. then the wood would catch fire. idea=stupid.
Well it works fine for me, this is after checking all connections tighten them all and such. Plus its a lot cheaper that buy a fuse block, I'm sure everyones got some scrap MDF layin' around !!!!!
2002 XLT
22" Greed Envy
4-Optidrive 15's
Optidrive 6000d
2 Alphacell Batts
http://www.teamdaily.com
http://www.mecacaraudio.com
http://www.luckysautosports.com
It's the fuse holder that's causing it probably... we use ANL ones like that at work and if you don't put them together in the right order they loosen up and melt like that. I had one come back and the garage manager put his new holder together in a different order and he hasn't been back since(this was like 6months ago)... what order are you puttign the washers/nuts on?
RF T1000-1bdCP and T400-4
Boston Acoustics SPG 555
Kenwood eXcelon 995
I dont see what order puttint it together in would make a difference. The fuse always goes in last. I had this happen to me once. I dont know what caused it. I just know it happened. Only things I could think of is moisture on the connections and fuse. loose fuse bouncing causing it to arc. Loose connections causing extra heat.
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
should go fuse, washer, lock washer, then nut. thats how you ALWAYS do it.
I thought it was ring terminal on bottom, nut, fuse, washer, lock washer, then nut? atleast that's how we do it.
*edit* just noticed the nut is fixed on the bottom, so ignore ring terminal on bottom.
I'd almost be willing to bet money this is your problem... because you have it going nut, washer, ring terminal, lock washer, fuse, washer, and nut.
Edited by Shyne151
Kenwood eXcelon 995
his is the base nut thats on permanently, then washer, ring terminal, lock washer, fuse, washer, then nut. Thats how I do all my Stinger fuse holders and I havent had any problems..
refer to chevyboy ^^...
Kenwood eXcelon 995
  • Who's Online   0 Members, 0 Anonymous, 547 Guests (See full list)
