Tahoe 2013/2014/2015 RF, FI, XS, SQ, TM, etc...
No, not adding speakers back there. Waste IMO. The guy originally asking was only replacing his factory speakers so it would make sense for him. thanks for the thought though. I'm not even so sure I will have speakers past the front yet, LOL
2007 Chevy Tahoe (SOLD)
2 ~ DC Audio 5.0K @0.67
3 ~ DC Audio 5.0K @1.0
1 ~ XS Power D4800
1 ~ XS Power D3400
8 ~ XS Power XP3000
320+ Sq. Ft. Sound Deadener
Pioneer AVH-X5500BHS
Are you planning on using speakers there yourself Karkov? If so then you could either put a pro audio tweeter there or either a set of 3.5's or 4" speakers and I'm sure you can get them loud. I think I wouldn't worry about it until everything was in to see what it sounds like but if you wanted some rear fill then you could go with one of these... http://www.sonicelectronix.com/item_43391_Rockford-Fosgate-PP8-T.html http://www.sonicelectronix.com/item_36732_80W-Rockford-Fosgate-Sound-Dampening-Material-Bundle.html http://www.sonicelectronix.com/item_19823_Rockford-Fosgate-Power-T142.html
Sorry Idk what was going on there,I hit post and nothing happened so I refreshed the page and it was posted several times. sorry bout that
25d9cf71-fff8-4b67-a8f5-28c80d5ea859_zps7d3fe7f6-90c4-4939-b709-43f0e5812212_zps
2018 Honda Civic Sport Hatchback (build in progress)
NVX Sound Deadener (Front Doors)
Stinger FAST Rings
Stock Electrical
SSA Evil 6.5's Front Speakers
Stock rear speakers
MB Quart ONX4.80 speaker amp
Rockford Fosgate T-1500bdcp
DC Level 4 12" D1 @ 2-ohm
Box In Design Stage
Stock Radio
My Build Log
Also, if my port is facing the rear hatch, could i attach a piece of MDF board somehow to the vehicle (not the hatch) to help eliminate hatch rattles or do you think it would act too much like an extended port? Basically from the bottom of the rear window and down, flat piece of wood Anchored solid to the vehicle, not the hatch, to eliminate the hatch from rattling like a mofo. Thoughts? I don't want to change the frequencies of the box though
Bump
1 ~ XS Power D4800
1 ~ XS Power D3400
8 ~ XS Power XP3000
Bump
I'm not an expert or anywhere close to it...but IMO if you did do that, I don't think it would change too much if the clearance was way bigger than the port opening. I can't see it helping a whole lot though since it's all about the compression inside of the car. It would be spendy, but you could make a large plexiglass wall sealing the rear hatch off completely? Not ideal, just throwing thoughts out there.
'98 Chrysler Concorde LXi
Pioneer DEH-80PRS (HU/processing)
Rockford Fosgate T1652-S (components) for front
Rockford Fosgate T1693 (6x9s) for rear
Rockford Fosgate T600-4 running those
Rockford Fosgate T1500-1bdCP running a
Rockford Fosgate T1D215 15"
in a 3.1 cu ft. net tuned to 34 hz (firing in cabin)
Kicker PKD1 (0 & 4 AWG)
stock 130 amp alt for now; One yellow top Optima
Installed everything myself & built box (brother helped)
Used a DD-1 to set gains.
Build Log: http://www.stevemeadedesigns.com/board/topic/165894-first-build-accumulated-since-i-was-14/
Just Pics: http://www.stevemeadedesigns.com/board/garage/vehicle/1463-chrysler-concorde-lxi/?tab=images
Is it done yet? Doesn't look like it is going to be much beyond 120db....
I hope that is sarcasm because if not then that just means you're a dumbass
