Tahoe 2013/2014/2015 RF, FI, XS, SQ, TM, etc...
Is that a PCM controlled alt?
Yes it is, PCM controlled (confirmed by mechman) and internally regulated.
2007 Chevy Tahoe (SOLD)
2 ~ DC Audio 5.0K @0.67
3 ~ DC Audio 5.0K @1.0
1 ~ XS Power D4800
1 ~ XS Power D3400
8 ~ XS Power XP3000
320+ Sq. Ft. Sound Deadener
Pioneer AVH-X5500BHS
What do you mean that's my problem? You're switching to external huh, i asked Mechman about that on the phone and they simply said "it's a internally regulated alt" so i figured i couldn't go external? I thought this thing was supposed to be hook up and go. Of course i don't know a lot when it comes to these things... What happens if i do nothing about it? It will let my voltage drop even when i have the subs in and playing? I don't get it
1 ~ XS Power D4800
1 ~ XS Power D3400
8 ~ XS Power XP3000
Send me pics of all ur ground runs and a shot of ur ground from battery to alt, I'm like 90% sure I know ur problem. And yes it's basically a stock alt it will turn off alot for no reason, and can have voltage spikes if its not setup right.
If you need I can talk u through it over the phone.
"SilveradoGoesBang"
http://www.stevemeadedesigns.com/board/topic/155256-silveradogoesbang-box-done-take-notes-on-bracing/
2 FI BTL 18's
CT Sounds 7k
2013 MidwestSPL Finals Xtreme 3 - 1st Place
I'll take a video of everything under hood when i go back out to where my Tahoe is, pulled it into a air conditioned shop outside of town.
1 ~ XS Power D4800
1 ~ XS Power D3400
8 ~ XS Power XP3000
Kk, how many ground runs do u have to ur alt?
With the PCM controlled alt u can't only have one and you have to get Reid of the factory ground. It has to be a pure ofc run and has to run through the sensor. Is that how u have it setup ATM?
You cannot! Do the regular big three or it will cause problems.
"SilveradoGoesBang"
2 FI BTL 18's
CT Sounds 7k
1 ground to the alt. it's a good ground to frame. 1 ground to battery, also ground good to frame. 1 power from alt to battery. factory ground in place as it was. 1 ground from body to frame. there is actually 2 grounds that were connected to factory battery, err 2 separate wires anyways, and then also 2 positive wires running to positive on battery, you can see that from picture up above. Ok, so get rid of factory ground. Everything aftermarket already is OFC wire. Factory ground to alt? Mine just had a plug and a positive, i think it's grounded by house/where it bolts in? Which sensor does what have to get run through? lol Also, yes unfortunately i did do standard bug 3 at this point.
At this point I will try and take out the big 3 and have it back to factory wiring except leave Mechman and XS power battery in? I will still post vids./pics. of it later today.
1 ~ XS Power D4800
1 ~ XS Power D3400
8 ~ XS Power XP3000
Otherwise with PCM controlled and internally regulated what would i have to buy to make it externally regulated? More than just a simple external regulator I would assume? Would i still have to alter the wiring?
1 ~ XS Power D4800
1 ~ XS Power D3400
8 ~ XS Power XP3000
I was gonna ask if the serpentine belt was slipping since the pulley on the new alt look to be smaller diameter than the stock alt, which could cause irratic or no charge, but then if that was the case you probably would've noticed a squealing noise
25d9cf71-fff8-4b67-a8f5-28c80d5ea859_zps7d3fe7f6-90c4-4939-b709-43f0e5812212_zps
2018 Honda Civic Sport Hatchback (build in progress)
NVX Sound Deadener (Front Doors)
Stinger FAST Rings
Stock Electrical
SSA Evil 6.5's Front Speakers
Stock rear speakers
MB Quart ONX4.80 speaker amp
Rockford Fosgate T-1500bdcp
DC Level 4 12" D1 @ 2-ohm
Box In Design Stage
Stock Radio
My Build Log
I had slimar issues with my toyota
I ended up grounding the
Alt to engine 0g
Alt to batt 0g
Where alt went to engine, (same bolt) engine to rails 0g
Batt to distribution block 0g
Distribution block to rail 4g
Distribution block to body 4g
Distribution block to ecu earth point(left original earth just went to same bolt) 4g
Distribution block to pcm earth point(did same as ecu) 4g
And that was just my earth
Pos was a bit easier
Alt bat 0g
Bat amp 0g
