Need help with 2 12" spl box!!!
Wizzy
Hi guys. I am trying to build my first spl box for 2 12" Ground Zero gzrw30spl.
Problem is that i have no ideea how to do a burp box for score. What frequency do i have to tune? How many liters? What port size? How to wire the coils? Where do i place the port ( sided, centered between the woofers ) ? etc...
What kind of port should i use? Slotport or aero? I would love to use one or 2 aeros but i have no ideea how to calculate them...
Car is a Ford Focus MK2 2007 4 doors hatchback.
Sub has to be in the trunk, subs facing up with port also up i think it will be better, if not please tell me.
I have a 3000 w rms @ 1 ohm amplifier for those 2.
Specs of the subs:
Model GZRW 30SPL
Diameter 300 mm / 12"
Mounting diameter 281 mm / 11.06"
Mounting depth 150 mm / 5.91"
Voice coil 63 mm Runddraht / 2.5" Round wire
Cone Verstärktes Papier / Reinforced paper
Power Handling 1000 W SPL Power
Impedance 2 x 2 Ohm
SPL 92 dB
Xmax 20 mm / 0.8"
Fs 33 Hz
Qts 0.36
Qms 5.97
Qes 0.38
Bl tesla-m 18
Vas 52 L / 1.82 cu.ft.
Box recommendation vented 55 Liter / 1.94 cu.ft. - Rohr / Tube 2 x Ø 8 cm / 3.15" - L = 20 cm / 8"
Box recommendation sealed 20 - 28 Liter / 0.7 - 1.0 cu.ft.
Please help me with a spl box design for those 2 woofers.
Can a do a box with a changeable port? I want to use it both for spl run and daily music if possible:D
Max dimensions would be 20" height x 35" wide x 16" widith.
Thanks in advance:)
I can't help but it may be a day befor some one who can help replays. Give it some time bro and people will help
2012 Chevy sonic1xSQ HDC3 12 D2RF R1200d
140 square foot of Q-Mat(soon to be installed)
140.2Db sealed on the dash with TL
142 DB sealed on the dash with another meter (was dead on with the TL at a show i was at)
141 on music.
strangeduck,on 02 Jan 2014 - 01:39 AM, said:
when my car spins out i just put the car in neutral, turn in the direction i want to go and pucker my asshole
ok thanks for the advice. im not in a rush :D altough im very excited about bulding the box because in 5 days i have a contest in my country and if i finish my system i will participate:D
You have to figure out your vehicles peak. IIRC reading about ways to find it a while ago people would use sealed box and find the peak in output, using test tones. You can do it by ear, but you could be a little off. When you find the peak build for your peak. Alsoyour enclosure is going to be based on more then tuning, how much power are you running, are you burping or going for high score on music? What competition and class are you competing? WHat are the limitations in the class?
If you use aero ports you could do a interchangeable port easier, but if you dont have access to them you can do a square port out of MDF, and make it removeable to change lengths whenever you want.
There are some real knowledgeable guys on here, there is a thread on here about getting the most out of your setup where the original poster tried a bunch of different things on the same enclosure, kerfs, 45's aeros, coating, position etc.
MY BUILD *****http://tinyurl.com/gmcbuild*****
Vehicles
2005 GMC Canyon
CB1000r - Currently where any future funds are going. (exhasut,bazzaz, ohlins shock, screen, etc.)
crf250r - Used to be race bike..now I just trail ride..practice at the track on it.
CH80 - Daily beater (when nice weather)best 150$ ever spent. 100+mpg
Sold to:
Skullz - pstone11 - Leo1103 - Volvo 63' - pavelpardo - imnew59585
Shower farts still piss me off.
I think theyre pretty neat. When the water runs down your crack as you let one out... its like shitting in a crockpot.
I don't know how much different the euro focus is compared to the american one but I can tell you the best configuration is woofers up and port firing towards the drivers side of the car. Everything up does not work well at all. I have about six years experience with the american zx3 and I was the loudest unwalled zx3 with all the equipment in the hatch in the USA. I am fairly lazy typing on my tablet PC at the moment but you can pm me with questions and I will answer them later from my desktop.
2013 VW Jetta GLI 2.0 Turbo
1 Sundown Audio SCV2000
1 Sundown Audio X15 V2
1 XS Power D3100
Audio Control LC6i
Stock Deck
2001 Focus ZX3: RETIRED
Highest NSPL Scores to date:
Limits in my class are 4000 rms, 2 batteries, stock alternator, 1 run of awg 0. backseats can be folded.
So the best response i can get in this focus is with subs up and port firing drivers seat?
I will run around 2200 watts at 2 ohms on those 2 12".
At the measure i will burp tones.
From what i remember my car's peak is 55 56 hz.
I dont know nothing about aero ports.
listen to nightshade great info on spl with the focus from him. he has done lots of testing in that car. peak is around 50-55hz of course thats all dependent on the direction of the box and the all around build.
my best (zx5) was with 2 t2d412 with a t1500.1bdcp. port and sub up port was on passenger side. could have been better if the port was on the driver side. did a 143 on a termlab with that and a 146 on an audio control. that was all before i started talking with nightshade. if i would have talked with him before hand i would have kept my 2 12s and tried playing around with new boxes for them. no i have 2 t2d415 that im doing a sub up port up build. cant do sub up port to driver side and still have the volume needed with the seat being able to latch and everything in the trunk under the window line.
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
  • Who's Online   0 Members, 0 Anonymous, 746 Guests (See full list)
