what is normal voltage drop? time for new alt?
solder myself... any and all wire
the resistance is minuscule... you have more resistance from the lug on the battery post than solder in the fucking lug
just solder your wire directly onto the posts
i have 2 runs of postive and negative... 0.00 voltage drop from front to back
0.00 from alt to front battery
You can solder directly to the post?
sure why not... get rid off all resistance! even if its so little it wont effect anything!
down rpping vanderbilt. 30 miles from victoria. i own the 3rd loudest setup here out of 3. but i did put together all 3 setups
^^ Cant wait to swalllow Ghost's babies
If soldering adds resistance, you're doing it wrong
2007 Pacifica
so you mentioned that you have 0.00v drop from the front to back of your car... perhaps i have a bad ground some place then because just going 6 feet i have a 0.12V drop along the wire?
nothing, gutted
could.. i have all CCA wire aswell :D
each run is about 10 feet long
all soldered
big 3 done
resting (no load 0 voltage drop)
under load (amp on)
0 voltage change from from to back
fluke 115 used
im going to go grind off all my grounds right now and get some fresh connections then ill report back with my min/max voltage drops. my tweets and mids ground to the body so perhaps i want to ground them t the frame as well?
im going ot swap my factory alt wire with a 2GA while im out there. would i benefit from adding a new ground from the mount bolts of the alt housing to the neg terminals? should i run the new alt charging wire to one of the batteries or to the copper fuse block?
nothing, gutted
Battery.
Zeke
'14
2003 Chevy Monte Carlo SS
Vehicle Details & Mod List: http://www.stevemeadedesigns.com/board/garage/vehicle/1703-chevrolet-monte-carlo-ss/
Audio Build Log: http://www.stevemeadedesigns.com/board/topic/143276-2003-chevy-monte-carlo-ss-audio-build-ib-build
Pioneer FH-P8000BT
Infinity Kappa Perfect 6.1
Fi IB3 (Two 12", 2-ohm SVC)
RF T400-2 & T500-1bdCP
MechMan S Series 240A
XS Power D3400 & D975
so..... yea.... all my charging issues ... it seems ive been driving around for the past 4 days with out a serpentine belt im gonna go get one now and try this testing again.
nothing, gutted
Uh, ... Can I get put on the back burner now?! lol
Zeke
'14
Pioneer FH-P8000BT
Lol that would cause some voltage issues
  • Who's Online   0 Members, 0 Anonymous, 1041 Guests (See full list)
