I have a slight whine noise coming threw my front door speakers but not
The rear speakers. Its on a Rockford prime 300.4. Both the front channel and rear channel are ran with the same exact rca's
They both have a no name brand rca, a y RCA with 2 female ends and one male,
Then the opposite one female and 2 male and they both plug in to the amp.
But once again I have only noise in the front not rear and its only when the radio volume.is off
Even on volume one I can't hear it or it gets drounded out.
So my question is should I just get new rca's and that should fix it?
Or go with a ground loop isolate?
Are you using a pioneer headunit?
If you swap the front and rear RCA's at the amp does the noise change from the front to the rear?
2010 Mazda 3s 2.5L
Pioneer DEH-X9600BHS
Knu OFC 1/0
SS Platinum AGM / XS Power XP750
Alpine PDX F-4 / Morel Maximo 5 + Coax 5
IA 10.1 / SSA XCON 12
So you have identified that the issue is the RCA cable itself then? Does the speed of the whine increase when you rev?
You might want to see if you can isolate or re-route it away from any factory electronics. Maybe some tech flex or wire loom might help.
To the rear
2010 Mazda 3s 2.5L
Knu OFC 1/0
I did that the first time I'm going with power down driver side then
RCA down the middle where there seems to be no stock wires
I had RCA ran the other side opposite of power but there is a lot of stock wire
All the way down on my f150
Should I put some tech flex over my power wire and big 3 in my engine?
Or would that not be it?
Run power down the side of car
And all speaker wires and rca down the middle
I don't buy that these days.
Maybe im weird.
I find it all comes down to what power, speaker and rca's you use weather you need to split it up
I normal power down the same side as batt and rca on the other, and if need be fit a magnetic cable shield (Philips make them and many other companies)
  • Who's Online   2 Members, 0 Anonymous, 949 Guests (See full list)
