Jskiles Posted July 3, 2013 Report Posted July 3, 2013 Right now I have a set of the skar audio vxi components and they aren't loud enough with the bass. Should I add another set and run them on the other two channels or go with bigger components or maybe some pro audio? 2010 Kia Forte Koup (Slow Build) 2 Sundown SCV-3000D 2 DC XL M1 with PSI reconesFocal R-165s2 on Orion 4800-HPKenwood KDC-X798Knukonceptz OFC 1/0Audiotechnix,Fatmat and Q-mat Deadener XS power D3400 up front 3 D3100s power in trunkStock 110 amp alt 2013 Scion TC 2 Dc lvl 3s with xl coils on Soundqubed 2200 Sundown components AA 50.2 for components Pioneer FH-X700BT Knukonceptz OFC 1/0 Fatmat and Q-mat Deadener XS Power D3100 up front D925 in back Mechman 240 alt http://www.stevemeadedesigns.com/board/topic/189911-2013-scion-tc-build/ <Scion TC Build http://www.stevemeadedesigns.com/board/topic/174094-jskiles-forte-koup/ <Slow Kia Forte Buildhttp://www.stevemead...ockUserAgent__1 < Old build 2005 Equinox
Jskiles Posted July 3, 2013 Author Report Posted July 3, 2013 anyone? 2010 Kia Forte Koup (Slow Build) 2 Sundown SCV-3000D 2 DC XL M1 with PSI reconesFocal R-165s2 on Orion 4800-HPKenwood KDC-X798Knukonceptz OFC 1/0Audiotechnix,Fatmat and Q-mat Deadener XS power D3400 up front 3 D3100s power in trunkStock 110 amp alt 2013 Scion TC 2 Dc lvl 3s with xl coils on Soundqubed 2200 Sundown components AA 50.2 for components Pioneer FH-X700BT Knukonceptz OFC 1/0 Fatmat and Q-mat Deadener XS Power D3100 up front D925 in back Mechman 240 alt http://www.stevemeadedesigns.com/board/topic/189911-2013-scion-tc-build/ <Scion TC Build http://www.stevemeadedesigns.com/board/topic/174094-jskiles-forte-koup/ <Slow Kia Forte Buildhttp://www.stevemead...ockUserAgent__1 < Old build 2005 Equinox
KMS Posted July 3, 2013 Report Posted July 3, 2013 If you're on somewhat of a budget, the Morel Maximo 6.5's have some good bass. Hell, my JBL MS-62c bump but cost a big more. Best thing to do is seal and deaden your doors. That will make a huge difference. Alpine PDX-V9 Morel Tempo 6 Alpine SBR-S8-4 Alpine CDE 149BT
Kevin M Posted July 3, 2013 Report Posted July 3, 2013 How much wattage are they on? Can you bridge the amp? If they are at or around rms feeding them a little bit more may be just what the doctor ordered. I would definitely try that before I added another comp set or changed to a PA setup. 2005 Ford Focus zx4 AMT's and Planars 18" Infinite baffle
Jskiles Posted July 3, 2013 Author Report Posted July 3, 2013 How much wattage are they on? Can you bridge the amp? If they are at or around rms feeding them a little bit more may be just what the doctor ordered. I would definitely try that before I added another comp set or changed to a PA setup. My amp is a orion 4800 which is rated 65 watts rms x 4 @4 ohms 100 x 4 @ 2 ohms 200 x 2 @ 4 ohms bridged. These speakers are 60 watts rms and are 4 ohms. 2010 Kia Forte Koup (Slow Build) 2 Sundown SCV-3000D 2 DC XL M1 with PSI reconesFocal R-165s2 on Orion 4800-HPKenwood KDC-X798Knukonceptz OFC 1/0Audiotechnix,Fatmat and Q-mat Deadener XS power D3400 up front 3 D3100s power in trunkStock 110 amp alt 2013 Scion TC 2 Dc lvl 3s with xl coils on Soundqubed 2200 Sundown components AA 50.2 for components Pioneer FH-X700BT Knukonceptz OFC 1/0 Fatmat and Q-mat Deadener XS Power D3100 up front D925 in back Mechman 240 alt http://www.stevemeadedesigns.com/board/topic/189911-2013-scion-tc-build/ <Scion TC Build http://www.stevemeadedesigns.com/board/topic/174094-jskiles-forte-koup/ <Slow Kia Forte Buildhttp://www.stevemead...ockUserAgent__1 < Old build 2005 Equinox
Kevin M Posted July 3, 2013 Report Posted July 3, 2013 I would be nervous running three times rms to any comp set. You can check with the skar subforum but they will probably tell you to get another com set. A crossover will eat some of the power so you could be safe but without knowing more I wouldn't risk it. 2005 Ford Focus zx4 AMT's and Planars 18" Infinite baffle
Swordlordboy1234 Posted July 4, 2013 Report Posted July 4, 2013 I'd find more powerful comps and more power. Deadening is needed though it will help a lot My old YouTube channel : http://www.youtube.com/user/SwordLords1234?feature=mhee My old build log : http://www.stevemeadedesigns.com/board/topic/161872-96-accord-b2-sundown-sky-high-dc-power-re-re-build-for-heatwave/page-37 My New Build - http://www.stevemeadedesigns.com/board/topic/207041-2016-mazda-6-sql-build/ 2016 Mazda 6 Touring JL Fix 86 - OEM signal correction B2 prototype DSP 6to8 B2 Ref63 - 3 way active set 2 B2 Class H quattro's 1 B2 Zero.5R @.5 2 B2 HNv3 12 d2 B2 SLIP40 - Lithium in the trunk Northstar Group 35 under the hood 100ft 2/0 welding cable 30ft 4ga welding cable 20ft 8ga welding cable All stinger OFC speaker wire Soundrive custom RCA's Tons of attention to detail.... Can it be perfect?
Jskiles Posted July 4, 2013 Author Report Posted July 4, 2013 I would be nervous running three times rms to any comp set. You can check with the skar subforum but they will probably tell you to get another com set. A crossover will eat some of the power so you could be safe but without knowing more I wouldn't risk it. Thanks. I'm probably going to buy another set and give these to my wife. Hopefully I can find a decent set that can run 150-200 watts for around 200 2010 Kia Forte Koup (Slow Build) 2 Sundown SCV-3000D 2 DC XL M1 with PSI reconesFocal R-165s2 on Orion 4800-HPKenwood KDC-X798Knukonceptz OFC 1/0Audiotechnix,Fatmat and Q-mat Deadener XS power D3400 up front 3 D3100s power in trunkStock 110 amp alt 2013 Scion TC 2 Dc lvl 3s with xl coils on Soundqubed 2200 Sundown components AA 50.2 for components Pioneer FH-X700BT Knukonceptz OFC 1/0 Fatmat and Q-mat Deadener XS Power D3100 up front D925 in back Mechman 240 alt http://www.stevemeadedesigns.com/board/topic/189911-2013-scion-tc-build/ <Scion TC Build http://www.stevemeadedesigns.com/board/topic/174094-jskiles-forte-koup/ <Slow Kia Forte Buildhttp://www.stevemead...ockUserAgent__1 < Old build 2005 Equinox
Jskiles Posted July 4, 2013 Author Report Posted July 4, 2013 I'd find more powerful comps and more power. Deadening is needed though it will help a lot I just installed deadener (sp?) a couple days ago so im good on that. Will most likely buy a higher wattage set. 2010 Kia Forte Koup (Slow Build) 2 Sundown SCV-3000D 2 DC XL M1 with PSI reconesFocal R-165s2 on Orion 4800-HPKenwood KDC-X798Knukonceptz OFC 1/0Audiotechnix,Fatmat and Q-mat Deadener XS power D3400 up front 3 D3100s power in trunkStock 110 amp alt 2013 Scion TC 2 Dc lvl 3s with xl coils on Soundqubed 2200 Sundown components AA 50.2 for components Pioneer FH-X700BT Knukonceptz OFC 1/0 Fatmat and Q-mat Deadener XS Power D3100 up front D925 in back Mechman 240 alt http://www.stevemeadedesigns.com/board/topic/189911-2013-scion-tc-build/ <Scion TC Build http://www.stevemeadedesigns.com/board/topic/174094-jskiles-forte-koup/ <Slow Kia Forte Buildhttp://www.stevemead...ockUserAgent__1 < Old build 2005 Equinox
Hellbilly429 Posted July 4, 2013 Report Posted July 4, 2013 Bridge em, turn the the gain down and high pass filter up and see what they do, fuck it, if they can't get loud enough for you then burn em up 2018 Honda Civic Sport Hatchback (build in progress) NVX Sound Deadener (Front Doors) Stinger FAST Rings Stock Electrical SSA Evil 6.5's Front Speakers Stock rear speakers MB Quart ONX4.80 speaker amp Rockford Fosgate T-1500bdcp DC Level 4 12" D1 @ 2-ohm Box In Design Stage Stock RadioMy Build Log
