Add another set of components or bigger?
Jskiles
Right now I have a set of the skar audio vxi components and they aren't loud enough with the bass. Should I add another set and run them on the other two channels or go with bigger components or maybe some pro audio?
2010 Kia Forte Koup (Slow Build)
2 Sundown SCV-3000D
2 DC XL M1 with PSI recones
Focal R-165s2 on Orion 4800-HP
Kenwood KDC-X798
Knukonceptz OFC 1/0
Audiotechnix,Fatmat and Q-mat Deadener
XS power D3400 up front 3 D3100s power in trunk
Stock 110 amp alt
2013 Scion TC
2 Dc lvl 3s with xl coils on Soundqubed 2200
Sundown components
AA 50.2 for components
Pioneer FH-X700BT
Knukonceptz OFC 1/0
XS Power D3100 up front D925 in back
Mechman 240 alt
http://www.stevemeadedesigns.com/board/topic/189911-2013-scion-tc-build/ <Scion TC Build
http://www.stevemeadedesigns.com/board/topic/174094-jskiles-forte-koup/ <Slow Kia Forte Build
http://www.stevemead...ockUserAgent__1 < Old build 2005 Equinox
anyone?
2 Sundown SCV-3000D
Kenwood KDC-X798
Knukonceptz OFC 1/0
Stock 110 amp alt
2013 Scion TC
Sundown components
Pioneer FH-X700BT
Knukonceptz OFC 1/0
Mechman 240 alt
If you're on somewhat of a budget, the Morel Maximo 6.5's have some good bass. Hell, my JBL MS-62c bump but cost a big more. Best thing to do is seal and deaden your doors. That will make a huge difference.
Alpine PDX-V9
Morel Tempo 6
Alpine SBR-S8-4
Alpine CDE 149BT
How much wattage are they on? Can you bridge the amp? If they are at or around rms feeding them a little bit more may be just what the doctor ordered. I would definitely try that before I added another comp set or changed to a PA setup.
2005 Ford Focus zx4
AMT's and Planars
18" Infinite baffle
My amp is a orion 4800 which is rated 65 watts rms x 4 @4 ohms 100 x 4 @ 2 ohms 200 x 2 @ 4 ohms bridged. These speakers are 60 watts rms and are 4 ohms.
2 Sundown SCV-3000D
Kenwood KDC-X798
Knukonceptz OFC 1/0
Stock 110 amp alt
2013 Scion TC
Sundown components
Pioneer FH-X700BT
Knukonceptz OFC 1/0
Mechman 240 alt
I would be nervous running three times rms to any comp set. You can check with the skar subforum but they will probably tell you to get another com set. A crossover will eat some of the power so you could be safe but without knowing more I wouldn't risk it.
2005 Ford Focus zx4
AMT's and Planars
18" Infinite baffle
I'd find more powerful comps and more power. Deadening is needed though it will help a lot
My old YouTube channel : http://www.youtube.com/user/SwordLords1234?feature=mhee
My old build log : http://www.stevemeadedesigns.com/board/topic/161872-96-accord-b2-sundown-sky-high-dc-power-re-re-build-for-heatwave/page-37
My New Build - http://www.stevemeadedesigns.com/board/topic/207041-2016-mazda-6-sql-build/
2016 Mazda 6 Touring
JL Fix 86 - OEM signal correction
B2 prototype DSP 6to8
B2 Ref63 - 3 way active set
2 B2 Class H quattro's
1 B2 Zero.5R @.5
2 B2 HNv3 12 d2
B2 SLIP40 - Lithium in the trunk
Northstar Group 35 under the hood
100ft 2/0 welding cable
30ft 4ga welding cable
20ft 8ga welding cable
All stinger OFC speaker wire
Soundrive custom RCA's
Tons of attention to detail.... Can it be perfect?
Thanks. I'm probably going to buy another set and give these to my wife. Hopefully I can find a decent set that can run 150-200 watts for around 200
2 Sundown SCV-3000D
Kenwood KDC-X798
Knukonceptz OFC 1/0
Stock 110 amp alt
2013 Scion TC
Sundown components
Pioneer FH-X700BT
Knukonceptz OFC 1/0
Mechman 240 alt
I just installed deadener (sp?) a couple days ago so im good on that. Will most likely buy a higher wattage set.
2 Sundown SCV-3000D
Kenwood KDC-X798
Knukonceptz OFC 1/0
Stock 110 amp alt
2013 Scion TC
Sundown components
Pioneer FH-X700BT
Knukonceptz OFC 1/0
Mechman 240 alt
Bridge em, turn the the gain down and high pass filter up and see what they do, fuck it, if they can't get loud enough for you then burn em up
25d9cf71-fff8-4b67-a8f5-28c80d5ea859_zps7d3fe7f6-90c4-4939-b709-43f0e5812212_zps
2018 Honda Civic Sport Hatchback (build in progress)
NVX Sound Deadener (Front Doors)
Stinger FAST Rings
Stock Electrical
SSA Evil 6.5's Front Speakers
Stock rear speakers
MB Quart ONX4.80 speaker amp
Rockford Fosgate T-1500bdcp
DC Level 4 12" D1 @ 2-ohm
Box In Design Stage
Stock Radio
My Build Log
  • Who's Online   0 Members, 0 Anonymous, 1145 Guests (See full list)
