alaskanzx5 Posted July 19, 2013 Author Report Posted July 19, 2013 the 80 prs has a built in x-over network. it allows me to set the x-over points myself. the punch pro tweets do have built in x-overs though. with this deck set it network mode it changes the rca outputs from front rear sub to high mid low. so the high(front) goes to the front channel input on the 4channel amp, the mid(rear) rca's go to the rear channel input on the 4 channel amp and the low(sub) rca's go to the sub amp as everyone should have been able to guess.. do a google search on active crossover networks and do some readin. active networks give you a lot more control over your speakers then passive x-overs. t1500bdcp 2 t2d4 15" 1 t600.4 1 t400.2 1 set p1 tweets singer alt, tons of wiring, smd vm-1, 80prs, back seat delete, still in the works, aiming for a 145-147 with the ability to play 25hz up to 50hz.
alaskanzx5 Posted July 19, 2013 Author Report Posted July 19, 2013 as an update, havent played with it much of any... i have had the kids with me and so i really havent had the time. t1500bdcp 2 t2d4 15" 1 t600.4 1 t400.2 1 set p1 tweets singer alt, tons of wiring, smd vm-1, 80prs, back seat delete, still in the works, aiming for a 145-147 with the ability to play 25hz up to 50hz.
Jessica Posted July 19, 2013 Report Posted July 19, 2013 the 80 prs has a built in x-over network. it allows me to set the x-over points myself. the punch pro tweets do have built in x-overs though. with this deck set it network mode it changes the rca outputs from front rear sub to high mid low. so the high(front) goes to the front channel input on the 4channel amp, the mid(rear) rca's go to the rear channel input on the 4 channel amp and the low(sub) rca's go to the sub amp as everyone should have been able to guess.. do a google search on active crossover networks and do some readin. active networks give you a lot more control over your speakers then passive x-overs. Actually i am pretty sure from top to bottom it is mid/high/low so your highs go to rear, mids to front, and subs to sub. edit: Actually i am certain of it. So if you don;t have it that way that might be why your mids don't sound right. Rest in peace, walled 87 accord build log 03' Corolla build with AA Mayhem inside. My super random youtube channel and terrible camera work. Wiring comparison by CaptainzPlanetz Wire and fuse guide by Guest SyKo13
RidingTooLow Posted July 19, 2013 Report Posted July 19, 2013 the 80 prs has a built in x-over network. it allows me to set the x-over points myself. the punch pro tweets do have built in x-overs though. with this deck set it network mode it changes the rca outputs from front rear sub to high mid low. so the high(front) goes to the front channel input on the 4channel amp, the mid(rear) rca's go to the rear channel input on the 4 channel amp and the low(sub) rca's go to the sub amp as everyone should have been able to guess.. do a google search on active crossover networks and do some readin. active networks give you a lot more control over your speakers then passive x-overs. That answers my question. I have been doing a lot of reading on this subject and it has been quite frustrating and I am avoiding making new threads. There is such thing as a dumb question on here. Lol
alaskanzx5 Posted July 19, 2013 Author Report Posted July 19, 2013 yeah i wasnt sure how the rca's went on the back but i do have them set up right. when i first put it all together i did do the mid and highs backwards but i noticed it right away. my mids sound a lot better then they did. im lacking in the midbass (60-80hz mostly) department though. the speakers just cant play into that range good enough. im gonna have to do an 8" sub in the front doors or kicks to fix that. t1500bdcp 2 t2d4 15" 1 t600.4 1 t400.2 1 set p1 tweets singer alt, tons of wiring, smd vm-1, 80prs, back seat delete, still in the works, aiming for a 145-147 with the ability to play 25hz up to 50hz.
bcbrassard Posted July 19, 2013 Report Posted July 19, 2013 There Pro Audio speakers, they don't play well in that range like most . T2652s play down to 50 hz ok but shine at 60-80. Cant wait to here how the T3652s sound on 150 watts each. The 80-PRS is a great HU for its ability to tune. One of the best for its price range, I think I paid $230 for mine, best buy I have made on HUs.
FeelDaBass Posted July 19, 2013 Report Posted July 19, 2013 I like the post. So active sounds much better, or is mainly more fun because there are more detailed settings? I have been pondering this, although I only have the one set of components and wouldn't have any rear fill. How do you have your setup? Just a front stage?Also, my -2 db on my RF crossover just bit the dust so now I have my passenger side at 0 db and my driver side at -2 db because the tweeters are a little harsh...but since this happened TODAY...I am seriously debating on going active with just my one set of T1652-S on all 4 channels of my T600-4. Tweeters might not like that so much however.. '98 Chrysler Concorde LXiPioneer DEH-80PRS (HU/processing)Rockford Fosgate T1652-S (components) for frontRockford Fosgate T1693 (6x9s) for rearRockford Fosgate T600-4 running thoseRockford Fosgate T1500-1bdCP running a Rockford Fosgate T1D215 15"in a 3.1 cu ft. net tuned to 34 hz (firing in cabin)Kicker PKD1 (0 & 4 AWG)stock 130 amp alt for now; One yellow top OptimaInstalled everything myself & built box (brother helped) Used a DD-1 to set gains. Build Log: http://www.stevemeadedesigns.com/board/topic/165894-first-build-accumulated-since-i-was-14/Just Pics: http://www.stevemeadedesigns.com/board/garage/vehicle/1463-chrysler-concorde-lxi/?tab=images
Jessica Posted July 19, 2013 Report Posted July 19, 2013 I thought the t2's had trouble below 120hz, may have been an issue with my install. Thats why i am going with some mid-bass drivers and switching to the t1's for the silks. Going to run active too. I guess i will see if the 16 band e.q. is enough to get the job done. Rest in peace, walled 87 accord build log 03' Corolla build with AA Mayhem inside. My super random youtube channel and terrible camera work. Wiring comparison by CaptainzPlanetz Wire and fuse guide by Guest SyKo13
DylanBunch Posted July 19, 2013 Report Posted July 19, 2013 I have question... sorry for thread jack.... the mids and tweets are on separate channels and the rcas are in right but the high hpf doesn't cross my tweets 2006 Ford Explorer 2 Team AA/Sundown 15s 6th order Ct Sounds 7k 4 PRV Mr500 8s Rockford p1000-2 Team Subsonic Lows
bcbrassard Posted July 19, 2013 Report Posted July 19, 2013 Actives the shit guys, way more control of your speakers and how they sound. My door are super sealed and sound deadened with acoustic foam. I really took the time to do it right and it made a huge difference in quality. The 16 band eq & being able to mute each channel to tune is awesome. I split the signals to run 2 T400-4s for front and rear doors for rear fill. TA'd for the front and the rear fill sound good as well. My next upgrade will be to add a T400-2 to run the T365 comps and use a channel from the T400-4 for T2s in the kicks. Not needed but I still want to try it. The video doesn't do the system justice, just shows how loud it can get. It was taken before any tuning was done.
