Jessica Posted July 8, 2013 Report Posted July 8, 2013 Just wire at 2ohm for now, upgrade your electrical when you can then wire at .5. Hopefully by then you will know your subs well enough you can do it without smoking them. Of course, you can always just turn the gain down, and use a remote gain knob to cut it back more. Rest in peace, walled 87 accord build log 03' Corolla build with AA Mayhem inside. My super random youtube channel and terrible camera work. Wiring comparison by CaptainzPlanetz Wire and fuse guide by Guest SyKo13
SnowDrifter Posted July 8, 2013 Report Posted July 8, 2013 So in theory the final load on the amp will be 2 ohm and realistically the amp will only be doing 1100 watts? You mean realistically the final load will be 2 ohms and theoretically 1100 watts? Yeah pretty much. Even less after box rise but that's a discussion for another thread/day lol ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444
Pierce Barrett Posted July 8, 2013 Author Report Posted July 8, 2013 Just wire at 2ohm for now, upgrade your electrical when you can then wire at .5. Hopefully by then you will know your subs well enough you can do it without smoking them. Of course, you can always just turn the gain down, and use a remote gain knob to cut it back more. That's true it's probably safer to run it at 2 ohm for a little while since I will only have 2 extra bats in my tool box and my stock 140 amp alt 2006 Ford F150 4.6 3v (2) Digital Deisgns 3515's D4 Digital Designs M3B w/ Toolmaker Dual Inputs Mike Singer Built 340 Amp Alternator Arc Audio KS 300.4 *mids and highs to come soon* Alpine 148BT And tons of 0 AWG
Pierce Barrett Posted July 8, 2013 Author Report Posted July 8, 2013 So in theory the final load on the amp will be 2 ohm and realistically the amp will only be doing 1100 watts? You mean realistically the final load will be 2 ohms and theoretically 1100 watts? Yeah pretty much. Even less after box rise but that's a discussion for another thread/day lol I was just about to ask about box rise HAHAHA 2006 Ford F150 4.6 3v (2) Digital Deisgns 3515's D4 Digital Designs M3B w/ Toolmaker Dual Inputs Mike Singer Built 340 Amp Alternator Arc Audio KS 300.4 *mids and highs to come soon* Alpine 148BT And tons of 0 AWG
IH8PunkRok Posted July 8, 2013 Report Posted July 8, 2013 Suspension stiffness, cone weight, effective cone area, motor force, suspension and coil travel, etc. so the whole sub, is basically what you are saying. Man I wish I had an SA 12 I could build a box for. The size of the box does two things 1.) determines resonance and 2.) provides acoustic suspension the port which everyone in the this thread, save purple and I, does some things as well 1.) Allows transfer of compressed air into and from the enclosure 2.) alters acoustic suspension (btw this is a super simple explanation just to save my fingers the work) so essentially the port and box work together to create the acoustic suspension which determines power handling which is the essence of the main question. you can have a 3 cube box for a 12 have the same mechanical power handling as a 1 cube box but in almost every case the larger box will be more musical as larger boxes carry a lower f3 and can provide a much larger range than a small peaky box. Furthermore they can be more efficient. Back in the day before power was cheap people won competitions with acoustic power. it seems acoustic power has been forgotten these days -Matt2005 Dodge Magnum RTJVC KD-AVX1 2 PPI S580.2 Obsidian Audio ST1 Horn Tweeters PRV 8MB450s Audio Legion 3500.1D 2 RE MT 18s 360 ah LiFePO4 BatterySHCA 2/0 155.2 @ 29 hzKicker CVR 15's buildDD 3512e buildMini T-Line Build(6) 8s BuildNightshade 15s Wall BuildMagnum AB XFL 12s BuildNewest Magnum Build
Jessica Posted July 8, 2013 Report Posted July 8, 2013 Maybe you should start a new thread, seems like a good topic to discuss. Rest in peace, walled 87 accord build log 03' Corolla build with AA Mayhem inside. My super random youtube channel and terrible camera work. Wiring comparison by CaptainzPlanetz Wire and fuse guide by Guest SyKo13
Pierce Barrett Posted July 8, 2013 Author Report Posted July 8, 2013 Maybe you should start a new thread, seems like a good topic to discuss. Defiantly a tomorrow thing lol I have work at 9 in the morning and yes I'm complaining but hey I like my sleep but look for it tomorrow 2006 Ford F150 4.6 3v (2) Digital Deisgns 3515's D4 Digital Designs M3B w/ Toolmaker Dual Inputs Mike Singer Built 340 Amp Alternator Arc Audio KS 300.4 *mids and highs to come soon* Alpine 148BT And tons of 0 AWG
SnowDrifter Posted July 8, 2013 Report Posted July 8, 2013 Suspension stiffness, cone weight, effective cone area, motor force, suspension and coil travel, etc.so the whole sub, is basically what you are saying. Man I wish I had an SA 12 I could build a box for. The size of the box does two things 1.) determines resonance and 2.) provides acoustic suspensionthe port which everyone in the this thread, save purple and I, does some things as well 1.) Allows transfer of compressed air into and from the enclosure 2.) alters acoustic suspension (btw this is a super simple explanation just to save my fingers the work) so essentially the port and box work together to create the acoustic suspension which determines power handling which is the essence of the main question. you can have a 3 cube box for a 12 have the same mechanical power handling as a 1 cube box but in almost every case the larger box will be more musical as larger boxes carry a lower f3 and can provide a much larger range than a small peaky box. Furthermore they can be more efficient. Back in the day before power was cheap people won competitions with acoustic power. it seems acoustic power has been forgotten these days I'd like to continue this conversation in PM so we don't clog OP's thread if that's cool with you ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444
