a thought popped in my head as i was doing my install and i want to triple check that i did it right. i have a 1ohm dvc 18" ssa zcon along with a AQ-3500.1. now the amp puts out 2600 at 2 ohms and 4300 at 1ohm. i needed to wire the sub to a 2 ohm so i followed a diagram that wired a 2ohm dvc to a 4 ohm load, in my case a 1ohm dvc to a 2ohm load.
now here is probably the dumb question, on the amp, there are four speaker wire terminals. its neg, neg. pos. pos. the outmost terminals are what i should be using with the one sub correct?
it dont matter it is bridged internally.
This. Just think of it as one big positive terminal and one big negative terminal broken down into two positives and two negatives for the ease of wiring multiple subs.
My name is AdamThis is my Civic Build.7" Samsung Tab 2Kenwood KDC-X896Clarion EQS746Sundown X-15DC 3.5k @2ohmHatersGonnaHate's 02 Civic UBLELD Bypass for Honda Civic/Accord/FitDon's Jeep Grand Cherokee Rebuild
N8ball2013 - i think you'd stick your dick in a blender if it told you it was 40 wtih two kids your age. lol
srp365 - If posting were picking up bitches, I'd be going home single tonight
looks like tony montana sneezed in your car.
Thanks. And sorry for the dumb question. I knew I did it right but something made me second guess myself so I wanted to be sure.
I had the same question a year ago, the manuals do not make it clear, dont feel dumb, these newer korean amps were different than any amp I had owned in the last 15 years.
I just got an SQ-2200.1 (basically AQ just changed name to SQ) and had the same question haha. Thanks for answering it! :D
FI BL18 Build Log: CLICK HERE!!
2003 Explorer Sport:
FI BL18
SoundQubed 2200 at 0.7ohm
Pioneer DEH-2500UI
Pioneer 6 x 8s
Rockford Fosgate 6 x 9s
5 ft^3 box at 35hz
Lots of Mega Mat
SkyHighCarAudio_zpse6b4e501.png3abb2365-8d29-422d-a446-efa7a74b8dba_zps70e62980.jpgFILogo_zps400b37c1.jpg
The only dumb question is the one you don't ask. It's normally better to ask first than it is to do something stupid and have to come ask later on what you did wrong :).
CURRENT SYSTEM:
  • Alternator:
    1. Stock alt on mids/highs
  • Batteries: (2) XS D1400s
  • Headunit: 80-PRS
  • Sub Amp: DC 5.0k
  • Mids & Highs Amp: CT125.4
  • Active Components:
    • Mids RE XXX 6.5c
Build Log
Highest Legal Score: 151.0 db
actually its not "bridged", u cant bridge a mono block amplifier, since there is only one channel. its internally paralleled.
  • Who's Online   0 Members, 0 Anonymous, 2045 Guests (See full list)
