Mechman Alternators
I purchased a 270a alternator from Mechman a few years back, and I noticed that if I remove the 0 gauge wire from the alt to the battery, the alternator will not charge. The voltage will be 14 for a split second, but then drop to 12v. I have a stock wire connected, but it doesn't seem to charge. Is this normal?
Edited by Shigshwa
^If that is the case then the stock wire probably has a very poor connection or is not connected at all. If everything is running well with the 1/0 the I honestly wouldnt worry about it. Everything is working fine.
Team NorthWestSPL
If you are removing the charge lead from the battery while the engine is running you could potentially damage the alternator. If you are having problems contact us for a RGA# so you can send it back to us so we can test it properly on the dyno
1-888-MECHMAN
  • Who's Online   0 Members, 0 Anonymous, 1746 Guests (See full list)
