How's your box look like?
I would consider it on the small side. It's around 2 cubes with a 3 inch aero. It's a temp box from just a tiny JBL 12" I use to use. I was wondering if the box could be the problem, I can't find the specs for a 12" UFO BTL though.
3" aero is wayyyyy too small for that sub.
If it's hardly moving, check for improper wiring and/or dead coil. Pop test and verify the coil resistance with a multi meter
Terminals could be labeld wrong. Pop test the sub.
I've had this problem with a dual sub box... they were hitting out of phase like a mother lol
<img src=http://i1332.photobucket.com/albums/w610/beastly666bassboy/IMG_9611192581855_zps9b9b76be.jpg border=0 alt= height="75" width="800">
Growing old is necessary... growing up is an option! Have fun or you might as well fall into a 6 foot deep hole. Its much easier to be smart and act stupid then it is to be stupid and act smart! You're only limited by your imagination! Stop limiting yourself! Optima yellow top6 guage cableJVC KD S36 headunitPower acoustik 1600w 750w rms @2 ohmsTwo MTX thunder 7000 10"sSealed box @4.04 ft^3Mojo Mat in the trunk Coming soon:1/0 awg cablebig 3... in 6 gauge(till i can get the money for 0)planet audio Crossover.2- 3.5's for the front.2- 6.5's for the doors2- 6x9's for the rear3- MB Quartz amps to power it all.1- 6" aeroport...soon! <p>My Log!
dude its simple two wires one fro the positive on the amp one from the ground. touch it to the terminal on the box. if the woofer moves you're good... if not your bad. test it like they said to. they know what they are doing... they wouldn't tell you to screw things up its a legit test! JUST DO IT! like nike. now that said. if you were that afraid of messing up the sub you would have had the installation done by someone who knows what they were doing... just saying. now test the damn thing and tell us what it does just touch it don't hook it up to full 12v for more than a second
Well just so you know I did pop test it and it moves out a decent amount. Also I've done all my own installations including 4 12's, 2 15's 1 18'' sp4 in my trailblazer and most recently walled off in my chevy cruze so this isn't even close to my first, this has just never really happened before. Regardless what is the next approach. I'm thinking I've pretty much pinpointed the problem using torres box calc. The box I'm using as a temp is only 1.77 cubic feet after displacements with a measly 12 square inches of port. So I can almost guarantee it is the box indeed.
No matter what youve done in the past youve got an issue now. Small box small port and possibility of a wiring mix up are all poossible causes. Try it om one coil. See what happens
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
gotta agree with N8 here... lil errors happen to the best of em.... but the best of em know how to find the errors... that's where the helpful folks here come in :D a sub is a sub and an amp is an amp but the wiring can lead to fuckin headaches especially if it something small and seemingly of no consequence :)
Before you go through the trouble of building a new box, i would take it out and free air it for a little bit. Do it with both coils and then each of the coils separately that way you can easily identify if a coil is bad. One of my buddies brought over his sub this morning and he only had one hooked up and it played fine. We were in the process of fixing up his box when i noticed only one coil was connected. we hooked both of the coils up and had the same problem you ran into.
[sharedmedia=garage:vehicles:2223]
CAFForumSig_zps376518ed.jpg?t=1364077982
SD, thank for the input. I would have replied earlier, but I was measuring the output of my amp with a yardstick . . .
damn dude that's just foul!
  • Who's Online   0 Members, 0 Anonymous, 3653 Guests (See full list)
