more alternator or more battery? which is better.
ok so I'm kind of planning and researching for future upgrades. I'm looking at a 6kw amp pushing two 15s is what I want. now I'm sure my stock electrical won't be able to keep up with this. so I'm thinking of adding a second stock alternator. I have two open spots in my engine bay... the power steering pump and the ac pump are gone... so room isn't the issue.
so I'm wondering for starting out with this would I be better off running two alternators and one yellow top or two batteries and one alternator. the alternator would be the most inexpensive to do... well the purchasing any way. so more alt or more battery which is best?
and how would I hook up the second alt. I'd assume splice into the control wires to add a second control set and then run the pos from the new alt to the pos on the stock located alt... right?
<img src=http://i1332.photobucket.com/albums/w610/beastly666bassboy/IMG_9611192581855_zps9b9b76be.jpg border=0 alt= height="75" width="800">
Growing old is necessary... growing up is an option! Have fun or you might as well fall into a 6 foot deep hole. Its much easier to be smart and act stupid then it is to be stupid and act smart! You're only limited by your imagination! Stop limiting yourself! Optima yellow top6 guage cableJVC KD S36 headunitPower acoustik 1600w 750w rms @2 ohmsTwo MTX thunder 7000 10"sSealed box @4.04 ft^3Mojo Mat in the trunk Coming soon:1/0 awg cablebig 3... in 6 gauge(till i can get the money for 0)planet audio Crossover.2- 3.5's for the front.2- 6.5's for the doors2- 6x9's for the rear3- MB Quartz amps to power it all.1- 6" aeroport...soon! <p>My Log!
There is no way you are going to run a TRUE 6k watts on 1 or 2 batteries and stock alts. Well you can, but you will be dropping into the 10s
'01 Dodge Stratass Sealed Trunk Build Log
2008 Honda Fit Sport Build Log
On 10/3/2013 at 10:00 AM, ROLEXrifleman said:
Anyone who says they knew everything they wanted out of life at 19 can go suck a bag of dicks cause they are lying to themselves or brought up in a cult.
Two stock neon alternators and s yellowtop won't be anywhere what you need for the current draw. If that is your budget, you don't want 6,000 watts.
IMO I would do the biggest alt u can anyways.
The more solid elec u have the better. And the big 3 is a must.
yup the big three is my next upgrade brfore anything else goes in my car.
the HO. alts aren't cheap. I think the neons come with a 120a alt stock so would the addition of another 120 suffice? I don't plan on ever going to anything bigger in this car... because I'll probably sell it with that system in it... so would that suffice? because I can get stock alts for 100 bucks rebuilt. or would the 400 dollar HO be a must? I'm trying to be fruggle and get what I want at the same time ya dig? lol
Just calculate the current draw and tell me if 200 amps were going to work. If you're going to sell it anyways then just stick with something around 1500-2000 watts.
charging power > reserve power IMO.
^^^THIS ALWAYS
unless you don't have the space for it
*Hummer H3*
HeadUnit
Pioneer AVH-X4600BT
Mids and Highs
8-CT Sounds Pro 8" 8ohm
4-CT Sounds Pro Tweeters
Amplifiers
1-CT Sounds 125.4
1-CT Sounds 60.4
1-CT Sounds 7000.1
Electrical
3-Runs of 1/0 CT Sounds
8-XS Power D3100
3-Iraggi 300 amp Alternators
Subwoofers
4-SQ Hdc3 15" Subwoofers
(Soon to be 4 15" Ct Sounds EXO)
  • Who's Online   0 Members, 0 Anonymous, 1204 Guests (See full list)
