DylanBunch Posted April 12, 2015 Report Posted April 12, 2015 Damn that looks good, can't wait to see videos 2006 Ford Explorer 2 Team AA/Sundown 15s 6th order Ct Sounds 7k 4 PRV Mr500 8s Rockford p1000-2 Team Subsonic Lows
Hardcore RS Posted April 13, 2015 Author Report Posted April 13, 2015 Thanks for posting Andre! Sorry Sander but i had to place your Facebook picture here ;
sencheezy Posted April 13, 2015 Report Posted April 13, 2015 oh boy 165db with 237 DC Volts 6 15" SSA Evils 3 HV Taramps T60k @.33 18 XS Power D3400s Add me on SC, FB, IG, and YT @ Sencheezy
SnowDrifter Posted April 14, 2015 Report Posted April 14, 2015 Wow! May I ask why the change from the 6th to the 4th? ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444
Quintine Posted April 15, 2015 Report Posted April 15, 2015 I would imagine there would be a little bit of bandwidth loss moving to a 4th and still pushing numbers in that 20-40hz octave. I await to see what numbers you are pushing with great anticipation. If you leave it till the last minute, it will only take a minute. Build Log - 4x12's Trunk Firing 6th
rocking.that.eclipse Posted April 15, 2015 Report Posted April 15, 2015 Jake was telling me about this. I wanna see some more
Hardcore RS Posted April 15, 2015 Author Report Posted April 15, 2015 jup guess will be lower on 20hz but from 25-40 will be higher if i follow bassbox pro. i hope bassbox pro is right
Quintine Posted April 15, 2015 Report Posted April 15, 2015 It seems to be pretty good, matches up with WinISD as well. They all run off the same formulas AFAIK. Only thing they cant account for is how the car will react What sort of gains db wise are you expecting to see in the 25-40 range If you leave it till the last minute, it will only take a minute. Build Log - 4x12's Trunk Firing 6th
Hardcore RS Posted April 16, 2015 Author Report Posted April 16, 2015 yes thats very true, but with my last install it worked fine so hope the car wont be an issue. its even stronger then before.
