rubenvanderwijk Posted July 18, 2013 Report Posted July 18, 2013 hello, i finally chose my amp and sub, soon i am getting a soundstream 1600d with a sundown sa 12 but now i need to know what's the best choice a D2 or D4? and why? greetings ruben
ToNasty Posted July 18, 2013 Report Posted July 18, 2013 d4 if only running a single 12 ***Super Sellers List***http://www.stevemeadedesigns.com/board/topic/25829-super-sellers-buyers
rubenvanderwijk Posted July 18, 2013 Author Report Posted July 18, 2013 thanks for the fast reaction man!
rubenvanderwijk Posted July 18, 2013 Author Report Posted July 18, 2013 i got one more question, this guy http://www.youtube.com/watch?v=JKSVALzxuB4 is running 1 sa 12 but he has a d2 and it's bumping good will the d4 bump even more?
Raptorman Posted July 18, 2013 Report Posted July 18, 2013 If you have a single sub, dual 2 will wire you to 1 ohm. Dual 4 will wire you to 2 ohm. Your amp puts out 1600 at 1 ohm though so it may be a little bit too much for the sub. Which is why you should wire it to 2 ohm. 1996 GMC Sonoma Four Fi BTL Neo 18's In 2:1 6th Order Bandpass 2 Ampere 5k's @ .5 TEAM FI TEAM #LITHIUMCANTDEMO On 10/20/2013 at 0:37 AM, KillaCam said: Fucking with a Prius driver is like making fun of a disabled kid. Pussies.
rubenvanderwijk Posted July 18, 2013 Author Report Posted July 18, 2013 maybe it's better to choose a lighter amp and then pick the d4?
SnowDrifter Posted July 18, 2013 Report Posted July 18, 2013 Just get the D4. You are over-thinking things too much. Get the coils to match your amp. Get d4 coils to wire to 2 ohms. Then if/when you get another sa-12, get that one with D4 coils too. That way you can run the amp at 1 ohm. The only reason we say D4 and not D2 is because your amp puts out too much power a 1 ohm for a single sub. But would be a good match for a pair ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444
Raptorman Posted July 18, 2013 Report Posted July 18, 2013 Choose a lighter amp, and get the D2.About 600rms:http://www.ebay.com/itm/Audio-Technix-400-1-amp-amplifier-400w-RMS-1000w-MAX-Class-D-1-ohm-stable-/111053254611?pt=Car_Amplifiers&hash=item19db4a2fd3 About 1200rms: http://www.ebay.com/itm/Audio-Technix-800-1-amp-amplifier-800w-RMS-2000w-MAX-Class-D-1-ohm-stable-/111053236151?pt=Car_Amplifiers&hash=item19db49e7b7 If you aren't too experienced I would suggest getting the 400.1 1996 GMC Sonoma Four Fi BTL Neo 18's In 2:1 6th Order Bandpass 2 Ampere 5k's @ .5 TEAM FI TEAM #LITHIUMCANTDEMO On 10/20/2013 at 0:37 AM, KillaCam said: Fucking with a Prius driver is like making fun of a disabled kid. Pussies.
justin0943 Posted July 18, 2013 Report Posted July 18, 2013 yelp just get the d4 so you can get another one to wire to 1ohm as a final ohm 02 dodge ram 1500 reg cab 3rd gen 2 sundown sd-2 d4 soundstream rub1.2500 amp all sky high car audio-fuse,fuse holder,wire,ring lugs and rca flex tech box design by Joe X supension-mcgaughys 2in drop spindal ,western chassis 6in flip kit,buddy custom c-notch 04 5.7l hemi motor swap and made it an slt eletric everthing youtube channel-http://www.youtube.c...43?feature=mhee http://www.stevemeadedesigns.com/board/topic/190882-02-dodge-ram-1500-3rd-gen/
ToNasty Posted July 18, 2013 Report Posted July 18, 2013 thats amp is fine if you get a d4. i had a sa12 d2 on a skarbage 1500 at 1 ohm and it was fine. just be easy on the gain and the volume knob and your fine ***Super Sellers List***http://www.stevemeadedesigns.com/board/topic/25829-super-sellers-buyers
