XS Power
Where did you wire it in to?
Wire it to the inputs on the amp and see what your drop is
I'll just go and buy a multimeter. Better now than never I guess. I'll report in a bit
What does your drop look like if you play a song with a fairly constant bass line?
Where is the meter reading from?
This was what I was trying to ask.
2007 M/T Honda Civic Coupe EX
(4) Sundown Audio X-8's
(2) Ampere Audio 3800.1's
(3) Stinger SPV-44 Batteries
(1) Mechman 240
3:1 Ratio 4th order sealed from the trunk
TEAM NWSPL
Best termlab scores to date in Honda trunk:
151.7db legal (official) IASCA trunk 3 class
Best termlab scores to date in my walled Subie:
152.9db legal (unofficial) IASCA advanced 2 class
155db outlaw
Not under a load. When I have the clamp on and the engine is on, it really reads 15 amps! I'll put a vid up to prove it
Edited by Shigshwa
In addition to the above, turn up the volume and start bumping too. Play a song with constant bass like thug motivation or something. Once you are dropping voltage, clamp your alt, measure the voltage at your alt (neg probe to case, pos probe to pos stud). And measure the voltage at the amp. Put the probes on the set screws for the power wire
I measured it. On music, it rises to 200A. Seems like my ECM only kicks in and delivers the extra amperage when constant bass is on. the voltage reads a constant 12.8 in this test. I'll get the vid up. I also discovered another issue. Seems like a wire somewhere on the positive smokes up when I play it full tilt.
