trent420 Posted July 27, 2013 Report Posted July 27, 2013 I'm about to put a MMATS 3001.1 in my 2001 eclipse. The manual that came with the amp says run 0ga to the rear and then use 4ga (minimum ) Going into the dual power and ground. I already have 4ga(Rockford Fosgate wire) in my car. I'd like to do another run of 4ga, instead of tearing out the 4ga and replacing it with 0ga. I calked a MMATS dealer and they said 2 runs of 4 ga would be OK. Is that right? It requires 2 100 amp fuses. Can 4 ga wire handle 100 amps? I need advice! Also... I'm doing a big 3 upgrade. I need battery terminals that will allow the (2) 4ga runs AND the connections for the extra wire for the big 3. What kind of terminals can I use?
diegoclass2010 Posted July 27, 2013 Report Posted July 27, 2013 i would probably do 2 runs of 0 gauge ofc or cca and call it a day. 4 gauge might work if both wires are ofc, i still wouldn't do it
ChevyBoy95 Posted July 27, 2013 Report Posted July 27, 2013 1 Run from the front battery to the back batteries of 1/0 OFC (at the least) Both Amplifier power and grounds with 1/0 CCA (at the least) overkill is better than underkill (FIRES!) Best Score to Date : 160.5 dB Outlaw (47Hz)[4 XM 15's & 2 Taramps Bass 12k's] BL : http://www.stevemeadedesigns.com/board/topic/147800-chevyboy95s-4-15s-7krms-wall-1533-db-on-half-power/YouTube: http://www.youtube.com/hitemwiththeflex/
Smoove Posted July 27, 2013 Report Posted July 27, 2013 I'm about to put a MMATS 3001.1 in my 2001 eclipse. The manual that came with the amp says run 0ga to the rear and then use 4ga (minimum ) Going into the dual power and ground. I already have 4ga(Rockford Fosgate wire) in my car. I'd like to do another run of 4ga, instead of tearing out the 4ga and replacing it with 0ga. I calked a MMATS dealer and they said 2 runs of 4 ga would be OK. Is that right? It requires 2 100 amp fuses. Can 4 ga wire handle 100 amps? I need advice! Also... I'm doing a big 3 upgrade. I need battery terminals that will allow the (2) 4ga runs AND the connections for the extra wire for the big 3. What kind of terminals can I use? 1 Run from the front battery to the back batteries of 1/0 OFC (at the least) Both Amplifier power and grounds with 1/0 CCA (at the least) overkill is better than underkill (FIRES!) Overkill is your friend, stop looking for sufficient. I know good electrical isn't cheap, but neither is buying another amp. 2 Team Fi 15's v1 2 DD M5's 970amps of Alt 6th order blowthroughThe truck Blowthrough build : http://www.stevemeadedesigns.com/board/topic/155555-smooves-1996-chevy-ext-cab-c1500-slow-build/The 350z build : http://www.stevemeadedesigns.com/board/topic/170694-smooves-2003-nissan-350z/ My FB page https://www.facebook.com/pages/Smooves-Car-Audio-and-performance/719746144805343 Team Fi Audio http://www.ficaraudio.com/
