Titebond myth?
Amart88
I was randomly reading a thread on different wood glues and some guy named "whirlwind" was going on about how Titebond 3 and PVA's in general
will erode away to nothing in within 5-10 years and fail...?? That's the only time I have ever read such a thing. I've always been told how good the Titebond glues are. Maybe he was referring to it being used in a marine environment.
Here's the article: http://instantboats.com/phpBB3/viewtopic.php?f=1&t=675
Thoughts, experience?
I use PL glue, messy to work with but holds well/fills them little gaps
On baffels when im sticking 2/3/4 togeather inwill use regular wood glue as its thinner
1998 gmc extd cab
12 crossfire C710s
4 SAZ-4500s
3 Singer 400A alts
buncha mids/highs
Team Asshole
But I do use TB II for ish like panel multiplying and such.
And, I also "smear" it. Lol. Cuz in my head it helps. Lol. ?!???
everything ive been told and from experience "smearing" it does make it bond better ive always done it lol
My setup,
Digital Designs M80
3 Re audio 10's ported tuned to 36 hz
Kenwood x-696
SHCA 0 gauge
Polk audio coax running off hu
Once you start building your own subwoofer boxes, the chance of having the same box for 10 yrs is close to 0%, so don't worry about it. But if it makes you feel any better, I have a box in my shop that I built back in 1996. Temps in my shop range from 120+ down to mid-teens. Box is still together.
Current system:
1997 Blazer - (4) Customer Fi NEO subs with (8) American Bass Elite 2800.1s
Previous systems:
2000 Suburban - (4) BTL 15's and (4) IA 40.1's = 157.7 dB at 37 Hz.
1992 Astro Van - (6) BTL 15's and (6) IA 40.1's = 159.7 dB at 43 Hz.
Yeah. I never said he was correct. Just first I heard of something like that. Them boat builders are a particular breed.
The reason I like TB is that it's sheer strength was around 2700lbs where Polyurethane was only around 1700.
I use both but found this chart interesting. :) Never know how long my enclosure will be in there . But I would like it to remain intact for however long I may be there. Probably a good bit of time. Only way I'm taking that out is when the truck is gone. lol
Goes from 105 in the summer to -35 in the winter here.
http://www.oldbrownglue.com/pdf/HowStrongisYourGlue_FWW.pdf
id be surprised if you can keep 1 setup in the same box for 5-10 lol
2006 Ford Explorer
2 Team AA/Sundown 15s
6th order
Ct Sounds 7k
4 PRV Mr500 8s
Rockford p1000-2
Team Subsonic Lows
  • Who's Online   0 Members, 0 Anonymous, 1167 Guests (See full list)
