Why people not like strapping amps?
Karkov
As title states, I see a lot of people on here swearing up and down they will never strap 2+ amps together. I am curious as to ALL the reasons why?
Truly trying to learn here, not argue.
Thanks in advance. =)
On a complete side note (instead of making new thread) do DC Audio amps do rated? The one(s) I am thinking of going with for a project would need to do what they say they would do rated to be feasible in that application. I.E. under rated? (proper electrical of course)
2007 Chevy Tahoe (SOLD)
2 ~ DC Audio 5.0K @0.67
3 ~ DC Audio 5.0K @1.0
1 ~ XS Power D4800
1 ~ XS Power D3400
8 ~ XS Power XP3000
320+ Sq. Ft. Sound Deadener
Pioneer AVH-X5500BHS
strapping 2 amps together ? like bolting them next together? using bungy cables to hold them down? or wiring separate amps to each sub
I run mine strapped and wire low as shit while strapped :)
TEAM SOUNDQUBED -- TEAM SOUTH
Evo X build log
Facebook page The Black Nasty
wtf is ghost lyric talking about lol. If you strap at 2ohm you are running each at 1ohm...i see members here complain about reliablilty issues but beyond that I have never done it or seen other reasons.
MY BUILD *****http://tinyurl.com/gmcbuild*****
Vehicles
2005 GMC Canyon
CB1000r - Currently where any future funds are going. (exhasut,bazzaz, ohlins shock, screen, etc.)
crf250r - Used to be race bike..now I just trail ride..practice at the track on it.
CH80 - Daily beater (when nice weather)best 150$ ever spent. 100+mpg
Sold to:
Skullz - pstone11 - Leo1103 - Volvo 63' - pavelpardo - imnew59585
Shower farts still piss me off.
I think theyre pretty neat. When the water runs down your crack as you let one out... its like shitting in a crockpot.
sorry mate i have never hear the term before and i was scared to google it because my safe search is off lmao!
Strapping usually means you wire to a higher ohm load which is less stress to your electrical system
Um.. no.
You only wire higher because the amps still see 1 ohm each if wired to 2 ohms.
I always strap my amps because it lets me wire lower.
I have "tested" a couple amps strapped at .5 (each amp saw .25ohm). They did fine, didn't gain a lot, but i don't have a termlab. It did gain though, i know the difference in strapping @ 2 (each amp saw 1ohm) and .5 seemed like more cone control, tighter response, and a general feeling of well being.
I had a bigger smile when strapped at .5 too. Of course, it runs the risk of letting all the magic smoke out when wired that low.
strapping is when you wire two amplifiers together (generally have a connection cable specifically for this) to achieve the power of both amps together. It essentially turns 2 amps into 1 big amp. You use the master amplifiers (amp 1) settings to control the slave amp (amp 2). Instead of wiring each amp separately at 1 ohm each, you generally will wire the subs to 2 ohms strapped... this will result in each amp seeing 1 ohm. When strapped you dont necessarily gain or loose power either. Strapping is almost like bridging channels, but instead you are bridging amplifiers.
2 2000w amps not strapped (1 ohm each) = 4000w
2 2000w amps strapped (2 ohm) = 4000w
hopefully this clears things up.
sounds like playing with fire... like 2 engines on the same crank shaft one hiccups and everything goes boom.. i usually calculate my impedance of subs and rms and purchase my amp around that. Kinda like when i bought my sub it was said to be 2 ohm and i seen my amp did 500rms at 2ohm and less rms at 4 ohms but when i received the sub i put my meter across it and it was showing 4 ohms and man was it a bitch trying to tell a customer service rep they sent me a 4ohm sub not a 2 ohm... his answer its same shit it doesn't give you more wattage its just ohms,,,, so i sat down and drew it on a piece of paper how it worked until he switched it out for me -.-' lol sorry for the rant / story
  • Who's Online   1 Member, 0 Anonymous, 1414 Guests (See full list)
