Bboytaktix's 2011 Subaru STI Modest SQ build
Mine isn't as big as other members here either but I am happy with it and that's all that matters to me.
2007 Chevy Tahoe (SOLD)
2 ~ DC Audio 5.0K @0.67
3 ~ DC Audio 5.0K @1.0
1 ~ XS Power D4800
1 ~ XS Power D3400
8 ~ XS Power XP3000
320+ Sq. Ft. Sound Deadener
Pioneer AVH-X5500BHS
exactly! I'm sure I will be happy with my build too, I have only heard great things about the GTI-series sub, and I already know that my P660c components perform very well when amped. I'll just need to take the time to tune it all at the end to tie the bass into the mids and highs, something I didn't quite do last build (even though it did sound real good).
2018 Golf R - Stealth SQ system build - C508GTI front (active), 2x Pioneer Z10LS4, Zapco DSPZ8, Clarion DPX11551 (Mono amp), Pioneer GM-D8604 (front stage amp), Pioneer GM-A3702 (rear fill amp)
SOLD! 2011 Subaru STI - 'modest' passive sq system - JBL p660c component (front) JBL P662 (rear) JBL W10GTI (sealed enclosure) 4ch JBL GO1004 (150RMSx4), Clarion DPX11551 mono amp (+-1200RMS@3ohms)
Great job thus far!! looking forward to the rest of the build! B)
2011 Nissan Altima aka Red Ruby
HEADUNIT: Pioneer AVH X2700BS
ELECTRICAL:
-Singer 230a
-Northstar gr34
-(2) Northstar SMS220 w/ Custom Terminals from 12V Metalworkz
-100% Welding Cable
FRONT STAGE:
-(2 Sets) Hertz HSK165
-Hertz HSK130
-Ampere Audio 125.4
SUB STAGE:
-(3) Sundown Audio SA REV2 12's
-Ampere Audio 3800.1 V2
MISC (NON AUDIO RELATED):
-Interior & Exterior Lights LED
-Gloss Black Roof (PAINTED)
-15% Front, 5% Rear Tint
-Roof Spoiler
-20" TSW Snettertons (20x8.5 front, 20x10 rear)
-Custom Projector Retrofit (FX-R 3.0, 6.5k HID, Morimoto Mini H1 (faux projector), Quad Starry Night Halos) ----- COMING SOON!!
-Aftermarket Fog Lights
-Custom Painted Engine Covers
My Build Log: http://www.stevemeadedesigns.com/board/topic/169869-woods-2011-altima-aka-red-ruby-new-video-more-updates/page-109
Retrofit Build Log: http://www.stevemeadedesigns.com/board/topic/185787-hid-projector-retrofitting-diy-by-wood/#entry2765346
thanks! hopefully more updates this weekend.
Got lots of work done this past weekend :D Big updates and tons of pics to come tonight. Also picking up my sub from UPS tonight so should have pics of that beast tonight as well! Thanks for all the comments guys!!!
ALRIGHT. here we go. Updates. Was a big weekend. DID WORK SON;
First off, finished my wiring by running the speaker wire to front/rear speakers on passenger side;
ran wire same as driver side (under kick panel with stock wiring) and then crossed over perpendicular to RCA cables to driver side to join other speaker wires. I was told crossing speaker wires perpendicular to RCA can help prevent noise.
Then, mounted the new P662's in the rear doors
Wiring the speaker wire through into the rear doors was relatively easy, popped the rubber wire loom off and used coat hanger to pull wire through. Front doors, not so easy since it was a 2-piece loom and the lower loom extended all the way into the door and was real tight around the OEM wiring. So I did it the best way I could, popped a small hole in bottom grommet, passed speaker wire through it then put speaker wire back inside second rubber loom all the way into the door. Was the only way to do it cleanly without completely hacking up the wire looms and grommets;
I then moved onto the trunk, started fitting/measuring/cutting up MDF pieces to contour driver side of trunk for the amp rack;
My amps are big, especially the 4-channel, so I could not fit them both in the trunk corner or on that side. Decided to mount mono amp in the corner and 4-channel on the floor right under it. Once I made that decision, the rest of the ideas began flowing out of my brain. Had to make it sturdy too;
First time soldering 0-gauge wire. Used a torch and some flux. Got the idea from steve meade videos while watching him fix some messed up chevelle car audio build. Not bad at all for my first time!
Then cut hole in carpet for main power wire;
Did the grounds behind the amp rack and carpet, wired it though;
ran 4-channel RCA's on opposite side of trunk and put them through carpet right where 4-ch amp will be sitting;
I then mounted a small piece of MDF at 45 degrees, joining the floor and wall piece. This not only added stability and covered the block that secured the two MDF pieces, but is the perfect spot to show off my fused distribution block;
covered that piece in carpet because when the amp rack cover goes on, since the distribution block is small and will have a plexiglass window on top, you will see the background a bit, whereas the amps you will only see the light-up logos with the plexiglass windows. Oh yeah, thinking ahead :P
next, mounted the 4-ch amp. Raised it on strips of MDF where the amp screws in. Two reasons; one to be able to push it a bit more forward in the trunk where the floor ramps up, and second (and more importantly) for better cooling. I will be adding fans to the amp rack as well to cool the amps;
Wired up the 4-channel amp and the distribution block. Left the mono amp out since I didn't have the sub nor time to hook it up. The speakers sound GREAT with the amp, and of course, they get extremely loud. Gain is set to half on the amp for front components and a bit less for rear speakers, and they get loud as F**K!! I have them on high pass filter, so not much bass, but that will change once I get the sub in.
PLEASE keep in mind the amp rack will have a VERY aesthetic cover over it, and what I built so far is the actual structural amp rack to hold both amps. It will be sexy when all finished, you shall see ;)
oh, and LASTLY, PICKED UP MY SUB TODAY FINALLY FROM UPS!!! this thing... looks....BEAST!!!!!!!
:good: i like it so far. waiting for more.
#teamihop
Two 12 inch DC XL's
Carbon Fiber Cap
Stetsom 7k
Shell of box / baffle built by me
Port / sealing the box by John Hone
Fuck midrange
Alpine-9886
http://www.stevemeadedesigns.com/board/topic/177428-97jettas-sql-trunk-wall-loudest-99-buick-century-custom-with-a-one-legged-owner/
price has no influence on how something sounds
I told him to move the fucking port.
they see me hoppin they stoppin they can't believe im so white and dirty
It looks like you got so drunk, that someone came up and stole your leg.
thanks dude! amp rack may seem ugly but wait until I get the other amp mounted on the upper part then build the cover :D should be sexyyy!
  • Who's Online   0 Members, 0 Anonymous, 1506 Guests (See full list)
