Voltage spikes when blipping the throttle?
So, I've just realised that when I blip the throttle in my car, I get voltage spikes in excess of 16volts.
Also, the alternator seems to cold charge at pretty much 15volts, which I feel is too high. It drops to around 14.6volts when warm....
So, whats going on? regulator on its way out? something else I've missed?
The alternator casing is connected directly to the battery with 0ga cable, as is the positive output terminal of the alt.
Any suggestions would be great!
Thanks!
Are we talking about a spike when you are at idle and revving? Or any change in RPMs?
There doesn't need to be a load on the alternator for it to slip.
  • Soon To Be
  • '04 Ford Escape
  • US Alternator 280A Hairpin
  • D4800 Under the Hood
  • (6) XP3000's in Rear
  • Pioneer DEH-80PRS
  • DD AW6.5 (2) per door
  • *Tweeter Unkown*
  • DD SS4a & C3d
  • (2) SCV4000 @ .5Ohm
  • (2) 15" Sundown Zv5
It spikes when you let off the throttle?
drive around at 2000rpm, and its "fine" (well, as fine as charging at nearly 15volts can be)
drop the revs suddenly, and the voltage spikes... (although it could be increasing the revs suddenly that causes the spike)
could it really be belt slip causing this?
He's saying when he revs it the alt spikes to 16v
Belt slip wouldn't cause that...especially with no load. Alt is probably bad, contact seller/manufacture and see what's up
Or OP is idling too low for it to turn on
Can you post a picture of the pulley size? Maybe a smaller pulley is in order? Some batteries/caps would help absorb the voltage spike too. Does it remain charging at 14.6 at idle or does it drop?
  • Who's Online   1 Member, 0 Anonymous, 1456 Guests (See full list)
