Batterys draining quuuuuick
I have a 1400 Kenetic up front and one in the back. Stock alt.
When I first got them, the voltage stayed up nice.. Now, it's just dropping down to 10-11's super fast.
AQ2200 @ 1ohm btw. What can I do to fix this?
Tested alt and its fine. Big 3 done also.
Team Subsonic Lows
Get your garbage EMF products of my amp bitch
Man....it makes a nice work bench ;)
Put the batteries on a charger overnight.
Load test the batteries the next day to verify their condition.
With the car off and batteries out, use a DMM on resistance and measure at the battery terminals.
Look for a parasitic low resistance which could be slowly draining your batteries.
If you have a current clamp meter, look around your electrical system for excessive currents (batteries re-installed).
First with the car completely off.
Then do the test with the ignition switch on and car not running.
Then do again with the car running.
How was the alternator verified?
This post sent with 100% recycled electrons.
2004 BMW M3
Mechman 280A
2 - XS Power XP3000
1 - XS Power D375
500F of Maxwell SuperCaps (soon to be 1000F)
iPadMini2
Dash mounted O-scope
Audison bitOne (Remote DRC MP)
Highs Amp - PPI Art A404
Hertz HSK130 (HSK165 waiting...)
DC Audio DC9.0K
2- DC Audio XL12m2
LEGAL             - 147.3dB @ 41Hz
OUTLAW         - 150.2dB @ 45Hz
OUTLAW         - 145.7dB @ 30Hz
JUNE 2014 SOTM WINNER
2014 COLORADO PEOPLE'S CHOICE WINNER
SOTM BUILD:
http://www.stevemeadedesigns.com/board/topic/141656-wicks-e46-m3-build-bass-turbo-button-and-a-big-new-addition/page-68#entry2802026
Take your battery and shake it around for a few minutes, turning it on its sides back and forth. Then recharge it with a trickle charger. If the battery is good then check your grounds. You could have a bad amplifier. You may have a blown a fet causing it to pull all the votage from the battery.
Whats the voltage with the car off after sitting for an hour?
I haven't changed my grounds though. So that shouldn't be a problem. It's grounded to the spare tire well.. Sanded of course.
Team Subsonic Lows
  • Who's Online   1 Member, 0 Anonymous, 1536 Guests (See full list)
