Won't charge up.. sitting at 12.5 *help*
Look under the hood and see if your belt is still there. If it is, measure the voltage at your alt with a multi meter. Pos probe to charge stud, negative to casing
Your serpentine belt was slipping on your alt, not too much you can do to fix it unless you want to fabricate.
plenty you can do. shorter belt, taller pulley on the alt, or just get down there and tighten the fuckin' thing.
so just tighten the belt?
if it is still there. check the belt for cracks, tears, and check it for bare cord showing. if you see any of that then just replace the belt.
Owner of BigAss Ports
no its in great condition but the middle pulley wobbles a bit.. and the belt is a bit loose...
02 impala
VM-1
2 dc 12 xl's
RF t2500bdcp
Second skin damp pro
Kenwood head unit
240 mechman alt
d3400 in the front
d3100 in the rear
50ft Rockford fosgate ofc 1/0
Have the alternator tested somewhere.....its obviously not charging. Check the lead wire going from alt to battery. Slim chance but it could of gotten pinched or maybe fuse on it popped
Team Flex Issues
I mean this is the kindest way possible: You don't strike me as one who knows your way around under the hood very well. Pulleys shouldn't wobble at all. Perhaps you might be better taking this to a mechanic? You can really mess some stuff up if you don't know what you are doing
Alt belt??????? Your alt is not charging if you see 12.xx with the car on....
not always true. my pt cruiser only charged 12.6v
If I usually charge at 14 and than its in the 12s the alt is the first thing I'd check
I've had good belt slip but it'll eventually catch and start charging again
Team Flex Issues
CORRECT ... He already stated that HE USE TO SEE 14.xx
SOOOOOOOooooooooooooooooooooooooooooooooooooooooo im just sayin....
thanks for being kind and ya im still a damn kid im learning everything I can! I try to learn more and more everyday. thanks for keeping it kind.. and I'm pretty sure it just needs to be tightened thank you for the help tho!
02 impala
VM-1
2 dc 12 xl's
RF t2500bdcp
Kenwood head unit
240 mechman alt
d3400 in the front
d3100 in the rear
I will let you guys know what happens when I tighten it thank you for all your help.
02 impala
VM-1
2 dc 12 xl's
RF t2500bdcp
Kenwood head unit
240 mechman alt
d3400 in the front
d3100 in the rear
If you tighten it on a pulley with a blown bearing it will only make things worse
