Cresendo BC3500 issue.
Amart88
Have you tried running them strapped and using the bad one as the slave to see if that works?
Not yet, Don't really want to pull the woofers again, or do I need to?
Does it have a Master/Slave switch? If so have you tried switching it back and forth while its on to see if it starts playing?
Nope, will try that tomorrow. Making a list of things to try.
Worst case. How much do used 3500's go for around here? or to get repaired?
The master/slave switch will do it if its on slave
Something to try
EDIT: each amp is at 1 ohm. 2 woofers to each amp. dual 1's.
I know they are both on master. Checked. I will try switching back and forth. Then I will strap them and at least get all 4 moving.
I'm tired and exhausted so... strapped the amps are stable at 2 ohm? correct? all I do is runn the jumpers ans move my speaker wires to the correct spot? don;t neeed into the box.
what about your rca give them a look
02 dodge ram 1500 reg cab 3rd gen
2 sundown sd-2 d4
soundstream rub1.2500 amp
all sky high car audio-fuse,fuse holder,wire,ring lugs and rca
flex tech
box design by Joe X
supension-mcgaughys 2in drop spindal ,western chassis 6in flip kit,buddy custom c-notch
04 5.7l hemi motor swap and made it an slt eletric everthing
youtube channel-http://www.youtube.c...43?feature=mhee
http://www.stevemeadedesigns.com/board/topic/190882-02-dodge-ram-1500-3rd-gen/
How do you have the rca's? Input to one than pass through to the other one?
I had mine like that and the one that was getting the rca off the hu didn't like it. Had to switch them and it was fine
Yeah Mine come off the HU into first amp and then from first amps outputs into second. How do you have them now?
  • Who's Online   0 Members, 0 Anonymous, 951 Guests (See full list)
