Kian Posted February 25, 2008 Report Posted February 25, 2008 ok i am about to purchase a fi ssd 12inch and i was wondering should i get a dual 1 ohm or a dual 2 ohm. and is the dual 1 ohm = a 2 ohm amplifier??? --------------------------------------------------------------- Club 150 (15x.x) Youtube Future Build: 1x 15" T3 TSNS 2x Sundown Audio SAZ3000d Parellel strapped
Derrick824 Posted February 25, 2008 Report Posted February 25, 2008 What amplifier are you going to be using? Its better to pick your amplifier first then buy a sub to match it.
loganberry Posted February 25, 2008 Report Posted February 25, 2008 ok i am about to purchase a fi ssd 12inch and i was wondering should i get a dual 1 ohm or a dual 2 ohm. and is the dual 1 ohm = a 2 ohm amplifier??? dual 1 can be either .5 or 2 ohm, dual 2 can either be 4 or 1 ohm... dual 2 would be best if ur amp is only 1 ohm stable but it all depends on ur amp, pick you powerplant before you make ur choice My F-150 Build GET ON THE BANDWAGON what if they tried messing with the amps when the subs werent louder hahah jk
Decaf Posted February 26, 2008 Report Posted February 26, 2008 ok i am about to purchase a fi ssd 12inch and i was wondering should i get a dual 1 ohm or a dual 2 ohm. and is the dual 1 ohm = a 2 ohm amplifier??? yes in series dual 1 ohm if u plan on powering it @ 2 ohms
Kian Posted February 28, 2008 Author Report Posted February 28, 2008 thanks i will be getting a hifonics amp. --------------------------------------------------------------- Club 150 (15x.x) Youtube Future Build: 1x 15" T3 TSNS 2x Sundown Audio SAZ3000d Parellel strapped
Torres Posted February 28, 2008 Report Posted February 28, 2008 getting a dual 2 ohm sub would be best then. wire it in parallel to give the amp a 1 ohm load. EDIT: if the power @ 1 ohm on the amp is the power you wanna give the sub that is...
