mejweez Posted August 13, 2013 Report Posted August 13, 2013 am planning to bulid a ported box for 2 JBL 12" (P1224) but am confused what wil be better a box that has a divider for each sub so that they are sealed from each and each one has it's own port or combined with one port ?? what do u recommend
Sergeant_Skyrim Posted August 13, 2013 Report Posted August 13, 2013 Or you could even do separate chambers for the subs with a center port that's shaped like an L into each of those chambers. What's the setup though? Vehicle, orientation, etc? Build in progress
hdorre Posted August 13, 2013 Report Posted August 13, 2013 combined On 5/8/2011 at 7:38 PM, Kranny said: On 5/8/2011 at 7:35 PM, 'Maxim' said: It hurts me inside when I read stuff like this and remember you're 15 LMFAO so true Mitsubishi 3000GT (Old Build) Headunit: Pioneer 80PRS Frontstage: (2) McLaren Audio MLT-2 Tweeters & (4) PRV Audio MR Series Neo 6.5" Mids Substage: 4 15" Hybrid Subs - Tantric Motors & Sundown Softies Amps: Banda 2.4D Amp (Tweets), American Bass VFL 350.4 (Mids), and (2) Ampere 3800s Electrical :Singer 260A Alt & JY Power Lithium 2005 Chevy Colorado Ext Cab Headunit: Pioneer 80PRS Frontstage: 4 PRV 700Ti Tweets & 6 10" Delta Mids on 3000wrms Substage: 6 Fi BTL 18s in a 4th Order Walkthrough on 3 Wolfram 4500s Electrical: Singer "390" and JY Power My Official Feedback Thread
bkolfo4 Posted August 13, 2013 Report Posted August 13, 2013 X2 on combined, but I would do the port between the subs for a daily music box. Current system: 1997 Blazer - (4) Customer Fi NEO subs with (8) American Bass Elite 2800.1s Previous systems: 2000 Suburban - (4) BTL 15's and (4) IA 40.1's = 157.7 dB at 37 Hz. 1992 Astro Van - (6) BTL 15's and (6) IA 40.1's = 159.7 dB at 43 Hz.
mejweez Posted August 13, 2013 Author Report Posted August 13, 2013 Or you could even do separate chambers for the subs with a center port that's shaped like an L into each of those chambers. What's the setup though? Vehicle, orientation, etc? rockfordfosgate R1200.1d 2 12" JBL P1224 2004 Hyundai elentra
Sergeant_Skyrim Posted August 13, 2013 Report Posted August 13, 2013 Or you could even do separate chambers for the subs with a center port that's shaped like an L into each of those chambers. What's the setup though? Vehicle, orientation, etc? rockfordfosgate R1200.1d 2 12" JBL P1224 2004 Hyundai elentra Are those subs dual 2 ohms wired to a final load of 2 ohms at the amp? Tried googling and the JBL site says that they either come 2 or 8 ohm but that they're DVCs. And what's your goal? Just a daily vehicle for you to listen to? Build in progress
mejweez Posted August 13, 2013 Author Report Posted August 13, 2013 Or you could even do separate chambers for the subs with a center port that's shaped like an L into each of those chambers. What's the setup though? Vehicle, orientation, etc? rockfordfosgate R1200.1d 2 12" JBL P1224 2004 Hyundai elentra Are those subs dual 2 ohms wired to a final load of 2 ohms at the amp? Tried googling and the JBL site says that they either come 2 or 8 ohm but that they're DVCs. And what's your goal? Just a daily vehicle for you to listen to? they are dual 4 ohms the final load for the two subs will be 1 ohm 800 RMS i listen to rap usually , and yes it will be for daily use
Sergeant_Skyrim Posted August 13, 2013 Report Posted August 13, 2013 I vote for center port with either subs and port firing forward if you're sealing off the trunk, or both firing to the rear if you're not Build in progress
mejweez Posted August 13, 2013 Author Report Posted August 13, 2013 I vote for center port with either subs and port firing forward if you're sealing off the trunk, or both firing to the rear if you're not what do mean by sealing the trunk ??
Sergeant_Skyrim Posted August 13, 2013 Report Posted August 13, 2013 Sealing the trunk = making sure that all of the empty airspace in the trunk stays in the trunk. Box gets pushed all the way up the the front and then you seal off all the airspace around it with panels/foam/however you want to do it. Basically reduces the size of the cabin Build in progress
