DylanBunch Posted August 15, 2013 Report Share Posted August 15, 2013 I have a kicker 350.4 and I have 2 rcas run to the back but when I unplug the one going into the highs input on the back of my 80prs it doesn't cut off the highs, but if I unplug the mids rca it cuts off everything. I have my 4 mids on channels 3 and 4 and my super tweets on channel 1 and 2. Anyone have an explanation? Because of this I cant run my supertweets without those bulky ass crescendo crossovers because the high high pass filter on the headunit doesn't do anything because or some reason the amp and/or headunit things my super tweets are mids 2006 Ford Explorer 2 Team AA/Sundown 15s 6th order Ct Sounds 7k 4 PRV Mr500 8s Rockford p1000-2 Team Subsonic Lows Link to comment Share on other sites More sharing options...
bcbrassard Posted August 15, 2013 Report Share Posted August 15, 2013 Are you running active? Did you reset your HU when you switched it over? Link to comment Share on other sites More sharing options...
bbeljefe Posted August 15, 2013 Report Share Posted August 15, 2013 There is a push button switch to the left of the RCA inputs on the amp. If it's depressed (in) the amp uses both sets of inputs and if it's not depressed (out) the amplifier uses all four inputs. Facebook: facebook.com/audioanarchyllc Instagram: audioanarchyllc Youtube: youtube.com/bbeljefe Link to comment Share on other sites More sharing options...
DylanBunch Posted August 15, 2013 Author Report Share Posted August 15, 2013 yeah im running it active, I have all my crossover set up and everything sounds good but if I mute the high hpf it doesn't mute the super tweets and if I mute the mid hpf it mute everything.... don't understand. Maybe theres a switch on the amp that's 2 or 4 channel, im about to go play around with it 2006 Ford Explorer 2 Team AA/Sundown 15s 6th order Ct Sounds 7k 4 PRV Mr500 8s Rockford p1000-2 Team Subsonic Lows Link to comment Share on other sites More sharing options...
bcbrassard Posted August 15, 2013 Report Share Posted August 15, 2013 Most good amps usually have a switch. Link to comment Share on other sites More sharing options...
DylanBunch Posted August 15, 2013 Author Report Share Posted August 15, 2013 fixed, thanks guys 2006 Ford Explorer 2 Team AA/Sundown 15s 6th order Ct Sounds 7k 4 PRV Mr500 8s Rockford p1000-2 Team Subsonic Lows Link to comment Share on other sites More sharing options...
audiofanaticz Posted August 15, 2013 Report Share Posted August 15, 2013 also dont be hotswapping your rca cords when the stereo is on.. this is a quick way to ground out the center rca pin, and blow the output of your deck and introduce that annoying engine whine into your system (even if your headunit is not a pioneer, or dont have the picco fuse). Link to comment Share on other sites More sharing options...
DylanBunch Posted August 15, 2013 Author Report Share Posted August 15, 2013 also dont be hotswapping your rca cords when the stereo is on.. this is a quick way to ground out the center rca pin, and blow the output of your deck and introduce that annoying engine whine into your system (even if your headunit is not a pioneer, or dont have the picco fuse). Its funny you say that cause I read something about the the other day and then tonight... or this morning I should say, I did it not thinking and when I went back to my headunit it was on but blank and I immediately remembered and freaked so I restarted my car and now it seems fine..... nice scare of the day lol 2006 Ford Explorer 2 Team AA/Sundown 15s 6th order Ct Sounds 7k 4 PRV Mr500 8s Rockford p1000-2 Team Subsonic Lows Link to comment Share on other sites More sharing options...
