Aero-Port box vs Slot Port box?
chad190
But don't forget a cylinder naturally braces itself.
Like building a subwoofer from 1/4" thick cardboard sonotube. . .
Current system:
Previous systems:
2010 Kia Forte Koup (Slow Build)
2 Sundown SCV-3000D
2 DC XL M1 with PSI recones
Focal R-165s2 on Orion 4800-HP
Kenwood KDC-X798
Knukonceptz OFC 1/0
Audiotechnix,Fatmat and Q-mat Deadener
XS power D3400 up front 3 D3100s power in trunk
Stock 110 amp alt
2013 Scion TC
2 Dc lvl 3s with xl coils on Soundqubed 2200
Sundown components
AA 50.2 for components
Pioneer FH-X700BT
Knukonceptz OFC 1/0
XS Power D3100 up front D925 in back
Mechman 240 alt
http://www.stevemeadedesigns.com/board/topic/189911-2013-scion-tc-build/ <Scion TC Build
http://www.stevemeadedesigns.com/board/topic/174094-jskiles-forte-koup/ <Slow Kia Forte Build
http://www.stevemead...ockUserAgent__1 < Old build 2005 Equinox
by what?
By this thread. I'm still new to car audio and from what I'm reading about ports is making me want to tear down my box I'm building now and do some more research.
2 Sundown SCV-3000D
Kenwood KDC-X798
Knukonceptz OFC 1/0
Stock 110 amp alt
2013 Scion TC
Sundown components
Pioneer FH-X700BT
Knukonceptz OFC 1/0
Mechman 240 alt
by what?
Definetely worth it. Like Hugh said, I was a guy spitting out general rules of thumb. I don't do it anymore because I really don't know, since I have realized that I have sat down to do more research, I still barely know shit but a little bit more. And honestly, what I am going to do for now on. Is before I start a new build, just build several sheets of some cheap wood. Build several boxes and test out different port area's. Compare 2 of the same port areas to eachother, same depth, just different widths. That is really the best way to learn. Experiment.
  • Soon To Be
  • '04 Ford Escape
  • US Alternator 280A Hairpin
  • D4800 Under the Hood
  • (6) XP3000's in Rear
  • Pioneer DEH-80PRS
  • DD AW6.5 (2) per door
  • *Tweeter Unkown*
  • DD SS4a & C3d
  • (2) SCV4000 @ .5Ohm
  • (2) 15" Sundown Zv5
  • 3 years later...
On 8/17/2013 at 7:32 PM, Hugh G. Rection said:
well, there is alot of stuff that goes into figuring a port. your port size is dictated by many many things. the shape of the port contributes in that it is directly relevant to the efficiency of the port. the actual depth of the enclosure contributes to it since the depth of the enclosure will also have to be considered since it affects the internal wavelength, and how that will relate to the tuning of the port. the amount of power to the sub will affect its mechanical power handling, so there be an appropriate amount of back pressure inside the enclosure to help keep the sub under control mechanically, and there must be an appropriate compromise between mechanical control and cycling enough air to keep the subs thermal power handling in check. also, the proximity of the driver to any internal panels of the vehicle and how that affects the amount of forward pressure on the sub, and therefore also the mechanical power handling.
there are a few more factors involved as well, and this is the reason why i dont really offer many enclosure suggestions online beyond fabrication techniques and such. i only design enclosures for vehicles that i have here with me. with access to vehicle, i can verify all of my information and design the enclosure properly and get optimal performance out of it.
i am old school in that i believe that if a project is worth doing, then its worth doing right. i just cant bring myself to spread bullshit information online or design half ass enclosures that are about as far away from optimal as something can be. any generalized rule of thumb you try to use is only enough information to be dangerous. joe x is a prime example of this.
I signed up just so I could say AMEN to this post about how much information is needed to make a proper port and box. Box and port placement (design) has a lot to do with keeping the woofers under control.   I installed professionally from about 1987 to 2003. The hay days of car audio.  We didnt have computer programs to calc boxes and ports, we had scientific calculators and plenty of scratch paper and pretty much memorized Theile / Small calculations. ( I know Blaubox was out early on).  I now have a 16 year old kid who is getting into car audio, he comes home telling me this car audio store has a box for his truck (2005 f150 crew cab) that fits 2 10 inch subs, he wants me to buy it. I asked him what subs is the box designed for, he says "they told me any 10 inch woofers".  I told him no way, its junk. So off to Home Depot we went and picked up some 3/4 MDF, fiberglass resin, wood glue etc. Picked up 2 Fosgate p2d4-12s. I have a huge collection of old school amps. I should have taken pictures but was not really thinking about getting on any forums. He now has a very clean system, Fosgate Power 800@2 running 2 OHM bridged. ( I know its below Fosgate's recommendations).   Fosgate 400@4 running mids and tweets. He is loving it.  He really wanted to install my old school Fosgate Power 650 and Power 300 but I just couldn't. He hated going through the math for a several hours but now is telling his buddies that the pre-made boxes they bought from Walmart and Ebay are not right.   Also know this is an old thread, hope I didnt offend anyone.
Welcome to SMD. Glad to see you found us. Stick around and take some pictures to post if you can. I love the old school stuff.
Pioneer 80PRS
  • Who's Online   0 Members, 0 Anonymous, 688 Guests (See full list)
