help with adding subs
g2shuck
I just built my box and installed an sdc2.5 12 in the truck on 600rms and tuned to 35hz. Would it cuse a problem if I built some kick panels and added some 6.5 subs to the front for that in your chest bass? I am worried about cancelization. I would be using one hybrid audio i6sw on each side.
2000 Toyota Camry With Sealed Off Trunk
Sky High OFC Wiring
DC Power 270 XP Alt
AQ 2200 Sub Amp
Two DC Level 4 m2 12s
80 Mil Murdetmat
Gathering Parts For Wall Build.
Team DC Audio 2014 Member
I think it would cause problems since they will be subs also from what you are saying.
2012 Chevy sonic1xSQ HDC3 12 D2RF R1200d
140 square foot of Q-Mat(soon to be installed)
140.2Db sealed on the dash with TL
142 DB sealed on the dash with another meter (was dead on with the TL at a show i was at)
141 on music.
strangeduck,on 02 Jan 2014 - 01:39 AM, said:
when my car spins out i just put the car in neutral, turn in the direction i want to go and pucker my asshole
If you want to use them for midbass and go with an active set up, that would be perfectly fine to do but you don't want to mix subs with different locations.
01 Ford focus ZX3
Pioneer AVH-X491BHS
PPI PC 4800.2
Morel Maximo 6.5" x2
Is there a write up on here on how to do an active setup? This is the first time I have actually tried to build an sq setup. Now that I am a little older I relized I need more than just loud bass in a prefab box lol.
Sky High OFC Wiring
DC Power 270 XP Alt
AQ 2200 Sub Amp
80 Mil Murdetmat
Active is just have the small subs being wired to the amp, and using its cross overs set it right above where the sub cuts off
  • Soon To Be
  • '04 Ford Escape
  • US Alternator 280A Hairpin
  • D4800 Under the Hood
  • (6) XP3000's in Rear
  • Pioneer DEH-80PRS
  • DD AW6.5 (2) per door
  • *Tweeter Unkown*
  • DD SS4a & C3d
  • (2) SCV4000 @ .5Ohm
  • (2) 15" Sundown Zv5
Ok so my sub runs 25hz-80hz.
Run the 6.5 midbass subs in the kick panels at 85hz-180hz
Run the 6.5 mids in the doors at 200hz-3500hz
Run the tweeters in the A Pillars at 3500hz and up
Would this be right?
Sky High OFC Wiring
DC Power 270 XP Alt
AQ 2200 Sub Amp
80 Mil Murdetmat
It should work...you probably have to play around with cut-offs abit...especially since you have your tweets up at ear level and your mids in the doors..those would probably require the most tweaking to get them to sound proper...how much power are you planning on feeding the mid-bass, mids and tweets?
just because the "subs" are in front of you doesnt mean it will have "in your chest bass." lol.
Here is what I am thinking.
JVC KW-AV61 head unit.
MB Quart RA480.4 to run fronts and rears set at 200hz and up.
JBL P660C for front doors.
JBL P963 for rear deck.
PPI P600.2 Bridged at 600 watts at 4 ohms set at 60hz to 180hz for midbass sub
Sundown SA-8 V2 D2 in 0.5 cubes tuned to 60hz for midbass (recommended by Jacob Fuller)
Sky High OFC Wiring
DC Power 270 XP Alt
AQ 2200 Sub Amp
80 Mil Murdetmat
  • Who's Online   0 Members, 0 Anonymous, 449 Guests (See full list)
