Golitan11 Posted August 22, 2013 Author Report Posted August 22, 2013 LOL it is not because it is rated at 800W @ 2 ohms that I cannot run it at 800W @ 1 ohm! The gain can be set to whatever you like you know... Anyway yeah I set my gain with a DMM to get 800W @ 1 ohm (I tested the box terminals resistance just to be sure and it was really showing ~1,1 ohm with the DMM). My gain was already set with the subwoofer output level (on the headunit) to the maximum (which is +6). But some told me that it would more possibly clip at that level so I consider to reset my gain the subwoofer output level at 0 with a -5 dB test tone (instead of 0 dB) and when I want to show off I will just have to crank the subwoofer output level.
CleanSierra Posted August 22, 2013 Report Posted August 22, 2013 Whew, this thread is confusing. OP, you sound confused... Im not the one you want to try to troll. Just a fyi for you.
STEALTH808 Posted August 22, 2013 Report Posted August 22, 2013 I'm surprised no one caught this... OP, you have a D2 sub? But claim the sub is getting 800 watts rms which is what the amp is rated to do at 2 ohms. So you cannot be wired to 2 ohms nominal, either 1 ohm or 4 ohms. I wonder if you're wired to 4 ohms nominal. Also, you're going to want your sub level turned up, you're not getting full 4 volts output like that. How were the gains set? And I agree with Klown, for a single 12" I'd shoot for like 1-1.5^3 1^3??? TEAM SUNDOWN HAWAIIHAWAIICARAUDIO.NET 150Db Club 160Db club in the future I see krakin as a threat
Miguels Posted August 22, 2013 Report Posted August 22, 2013 have you tried moving the box? ls the box built sub up port up or sub up port back? is your box a prefab or custom design? my logshttp://www.stevemead...-my-new-set-up/my blow through loghttp://www.stevemead...future-updates/ 96 ss http://www.stevemeadedesigns.com/board/topic/164094-96-impala-ss-build/
k3n12ock Posted August 22, 2013 Report Posted August 22, 2013 *hear 05 xB - (2) EVIL 18s - (2) BC3500s - NO WALL Channel 1: http://www.youtube.com/k3n12ock Channel 2: http://www.youtube.com/MrK3n12ock2
Golitan11 Posted August 22, 2013 Author Report Posted August 22, 2013 My box is port up and subwoofer up (I was suppose to face it back but I did not have enough wire, like 5 inches lol, to connect the amplifier to the box terminals, so I cannot move it either I am really straight on wires). Anyway if it was facing back there would only be a small gap of like 3 inches between the subwoofer and the door so I prefer facing it up. My box, like I said, is a home-made ported one (2 cubic feet tuned at 35 hz, L-slot port).
Hellbilly429 Posted August 22, 2013 Report Posted August 22, 2013 Kicker's sound louder cause they rattle and distort, Sa's put out good clean sound, your ears are used to hearing garbage. Trust me, Sa's pound And that is not sealed off, and I know I would gain sealed off because it's louder with trunk open 2018 Honda Civic Sport Hatchback (build in progress) NVX Sound Deadener (Front Doors) Stinger FAST Rings Stock Electrical SSA Evil 6.5's Front Speakers Stock rear speakers MB Quart ONX4.80 speaker amp Rockford Fosgate T-1500bdcp DC Level 4 12" D1 @ 2-ohm Box In Design Stage Stock RadioMy Build Log
Golitan11 Posted August 22, 2013 Author Report Posted August 22, 2013 Me I loose all my bass the trunk open, it is way quieter inside (which is normal I believe because there is less resonance).
justin0943 Posted August 22, 2013 Report Posted August 22, 2013 Can't compare a brand new woofer to anything to till it is broke in, they will get louder as they loosen up. thats true my sd-2 10's they got louder when they got done breaking in 02 dodge ram 1500 reg cab 3rd gen 2 sundown sd-2 d4 soundstream rub1.2500 amp all sky high car audio-fuse,fuse holder,wire,ring lugs and rca flex tech box design by Joe X supension-mcgaughys 2in drop spindal ,western chassis 6in flip kit,buddy custom c-notch 04 5.7l hemi motor swap and made it an slt eletric everthing youtube channel-http://www.youtube.c...43?feature=mhee http://www.stevemeadedesigns.com/board/topic/190882-02-dodge-ram-1500-3rd-gen/
