I just ordered a new sub and amp set up. 2 American bass xfl 12's, with an American bass vfl 120.1 (2200W rms). I have a 2013 kia forte koup with the stock charging system and wiring. If you were using an amp with 2200w's would you recommend installing a second battery, just getting a yellow top, or using a cap? I've never used a cap so not really sure if they are worth the money. I would appreciate some help, I upgraded from one 12" mojo with a pr1000.1 Memphis amp. any suggestions would be great. first post here thanks guys.
With your charging system being stock, I would do upgraded battery for under the hood and another in the back.
stay away from yellow tops go XS Power.
Pioneer P99RS
Ampere 3800
2-Ampere 125/4
4-6.5 inch Hertz HSK XL Mids
2-5.25 Satori Mids
2-Hertz Silk tweeters
DC Audio Level 5/12
Skyhigh Wire
Mechman 320
XS Power D3100
1. Don't get a capacitor...they are useless
2. Your gonna need at least a strong starting battery, likely another one in your trunk. If u have more than 1 then getting them both the same style (you can't have a regular car battery inside the cabin..the fumes could kill you. Therefore u should have 2 agm/sealed batteries) many people use yellow tops but I have heard of problems withbl those too. Xs is the best but sears platinum die hards are good too and cheaper.
3. Look up how to do the "big 3" And do that
And most importantly...
4. Welcome to the forum :)
Car: 2000 Honda CRV
Battery: XS Power D5100R
Alternator: Stock 90A
Head Unit: Pioneer DEH-X9500BHS
Front Speakers: Alpine Type S
Rear Speakers: JBL GTO 628's
Wires: All Knu 4g. Soon to be 0g. Big 3 in 0g
Volt Meter: SMD VM-1
Amps: Rockford Fosgate T400-2, T1000-1bdCP
Subs: 2 SSA XCON 15's Sealed
Tint: Privacy glass + 5% in the back and 25% in fronts
Double post
Car: 2000 Honda CRV
IMO you'll want something bigger than those. Get the biggest you can fit in the front plus a d3400 or larger for the back. At this point I'm not sure it would be a productive use of money to buy a cap
Get what fits, if not the next one up from xs power. Then either a d3100 or something similar for the rear, big 3, run to rear, and strong ground you should be fine.
Those car audio caps are trash. But if you get 6 maxwell 2.6v 2600f and series them to 15v then you got 443 farads. I have 2 banks with 5k. Everything cost $300.. But a battery would bo in the rear.
  • Who's Online   0 Members, 0 Anonymous, 643 Guests (See full list)
