Box designer get in here! Please
sbg
Are you talking about an iso setup
If so
You mount 2 subs either cone to cone or cone to mag
On cone to cone 1 is reversed to the other so you have a push pull effect
Cone to mag they both go the same way
In an iso setup say cone to cone
The box net volume is halved (only 1 sub is in that box)
Turning 2 subs into 1 sub
On some occasions the power to each is halved so the 2 sub share the power of once ratted power
So if you were to do an iso set for 4 sub
In a cone to cone setup
The net volume would be equal to the net volume of 1 reg ported sub of the same size
There are a few good right ups about them
If you want to google it
When I get around to it, I'll post a video of my 2 12s in a regular cab full-size pickup setup in an Iso configuration. I may have a few pics as well.
while I am a fan of SSA, I (and hopefully you too sag) would like to see some designs of what the hell these guys are talking about and how all this reasoning works. Please bestow your wisdom upon us!
Some link on the topic if you are really curious:
http://www.eng.hifi.pl/dictionary/isobaric.php
Bottom line: for a SQ setup on tight fitting space, disadvantages: inefficient and not cost effective.
He already has the subs though Joe, and the amp. It may be best for him to just roll with 2 subs ported and be done with it. I wouldn't rule out doing 4 subs Iso if it were my ride and all of the equipment was already purchased.
idd go iso because you dont get shit for second hand stuff over here, so unless i want to pay again, idd use what i have
but then again sometimes im just lazy and a sealed box is easy to build and guaranteed to work and last compared to iso, where a miscalculation could mean a recone is needed
so if i was the op, idd way up all my options
use 2 of them and sell 2 or keep for rainy day
sell and get 2 better for that amps full power
run iso
run sealed
then on each do the pros and cons and pick what works the best for the outcome you want
Well, 4 cheap 12 subs to be placed in a not too big trunk sounds like bad start to me, OP keep it simple, sell the 4 little subs and get a couple of really better 12s and do a nice box for them, it will be louder than the iso setup, much simpler to build right and will sound nice as well, say a couple of Fi X or SSA GCONs on that power.
Yep joe that's what I have been thinking. Looking at the soundqubed 2.5 subs. 160$ each is vary fair in price.
01 focus se
110 amp alt
Big 3 sky high and stinger hpm ofc 1/0
Super start platinum AGM (starting)
2 runs of 1/0 Execution audio front to back
Kenwood double DIN DDx271
A pillars- orion 4" super tweeter and 2-1" alpines.
Orion xtx 64 in the front doors
2:1 4th order bandpass
Sealed off trunk
Digital designs deadener on roof/ rear deck
Orion hcca 12s (black coils)
Orion xtr3700.1
Orion xtr250.2 mid/highs
All sky high 1/0 in trunk dual runs(power/ground)
Sky high dual 1/0 inputs
2 xs power D3100 in back
Sky high batt blocks
Rose audio batt blocks
Stinger volt meter
All sky high 1\0 fuse and holders
Db link remote/ rca
  • Who's Online   0 Members, 0 Anonymous, 847 Guests (See full list)
