Ok so I've started hauling more stuff recently in my bed. My dad is anal about scratches on it so I was going to pick up some spray on or roll on bed liner to do rail caps. What brands should I look at? I just want something easy to do that will help stop scratches. Budget is about $30 to do just the rail caps.
I have a plastic liner on tailgate and inside bed that works good enough.
Thanks for the help guys
Cody C.
My SPL to SQ Build Log
Vehicle:
1997 Dodge Dakota Ext Cab 4x4 2009 Dodge Journey SXT
5.2L V8 Magnum 3.5L V6
Stock Alt
Equipment:
Headunit- Alpine CDE-147BT
Mids/Highs Amp- JL Audio G6600 Class AB 6 Channel
Sub Amp- Hifonics BRZ1700.1D @ 2 Ohms Taramps DSP3000.1D
Sub- Hertz Hi Energy 12" HX300D SounDrive SDA3 12
Tweeters- Rockford Fosgate Power Series Silk Domes Hertz Hi-Energy
Mids- Dayton Audio Reference 4" Full Range Drivers
Midbass- Silver Flute 6.5" Hertz Hi-Energy 6.5"
Processor- MiniDSP 2x4
RCA- 6 channels of SounDrive HF series
Wire- EB Flex 2/0
-Member of Team SounDrive
I used duplicolors stuff on the floor of my car. Works pretty well and holds up. Just be sure to do all the annoying prep work. That is very important
BHE Wall Build
TEAM DC Audio
TEAM XS POWER
1986 Monte Carlo
KMC Nova's 20"
4 DC XL's W/ PSI Recones
2 DC 5k's
Pioneer PRS 80
10 Audio Technix
6 XS Power D3100's
1 XS Power D3400
Mechman 220a Alternator
How about rustoleum? They have it at walmart for $7 a spray can. Get a can or two for what I'm doing. Should be good.
Thoughts?
Vehicle:
Stock Alt
Equipment:
Wire- EB Flex 2/0
Raptor
CURRENT SYSTEM:
  • Alternator:
    1. Stock alt on mids/highs
  • Batteries: (2) XS D1400s
  • Headunit: 80-PRS
  • Sub Amp: DC 5.0k
  • Mids & Highs Amp: CT125.4
  • Active Components:
    • Mids RE XXX 6.5c
Build Log
Highest Legal Score: 151.0 db
Thoughts?
I never used rustoleums spray liner.
I've used duplicolor spray liner. They're probly similar, but they don't have that grip to it. Like the texture of regular bed liner
BHE Wall Build
TEAM DC Audio
TEAM XS POWER
1986 Monte Carlo
KMC Nova's 20"
2 DC 5k's
Pioneer PRS 80
10 Audio Technix
6 XS Power D3100's
1 XS Power D3400
http://www.herculiner.com/
Prep work is a must AND the most important part IMO, as stated above
2007 Chevy Tahoe (SOLD)
2 ~ DC Audio 5.0K @0.67
3 ~ DC Audio 5.0K @1.0
1 ~ XS Power D4800
1 ~ XS Power D3400
8 ~ XS Power XP3000
320+ Sq. Ft. Sound Deadener
Pioneer AVH-X5500BHS
guys im just looking for something cheap for just the top rails. not doing the whole bed as i would like too. max budget is like $30 roll on or spray. something i can get at like walmart, menards, or farm and fleet. when i say spray im thinking aresol. not paint gun. if i had the money i would just get it professionally done but it is $650 to do my bed and rails. not including cost of repair of my rusted out wheel wells that are patched for now. if i can get enough of it for the $30 there are spots on my frame where the multiple coats of undercoat spray has worn off so im wanting to respray them. should i use bed liner or just the rustoleum rust control matte black stuff ive been using on my bumper.
Vehicle:
Stock Alt
Equipment:
Wire- EB Flex 2/0
Ok found the duplicolor at farm and fleet. $14 a can only need one can it seems like. Grabbing a roll of tape to tape off and the prep wipes. Gonna sand it with 140-180grit.
Hopefully it turns out good. 3-5 coats.
Vehicle:
Stock Alt
Equipment:
Wire- EB Flex 2/0
heres the results of the duplicolor bed armor. it does have a rubbery texuture. hopefully it last for a while. it definitely turned out good i think tho.
taped off ~6" from the bottom lip inside rail.
sanded with 150grit and then i hit it with a real fast rub of 80grit
20130907_145214_zps4ac17113.jpg20130907_150245_zps4163d9bf.jpg20130907_150317_zps937bfa4d.jpg20130907_150414_zpsc3997404.jpg20130907_150916_zpse163075f.jpg20130907_164516_zps6cc94fa5.jpg20130907_173950_zps71fc8de5.jpg20130907_174007_zpsac7426ba.jpg
i think it turned out great. 2 light coats and a 3rd medium and a 4th heavy coat.
leave any comments you want guys. :)
Cody C.
Vehicle:
Stock Alt
Equipment:
Wire- EB Flex 2/0
Cody C.
Nice man!
Came out great, good job
BHE Wall Build
TEAM DC Audio
TEAM XS POWER
1986 Monte Carlo
KMC Nova's 20"
2 DC 5k's
Pioneer PRS 80
10 Audio Technix
6 XS Power D3100's
1 XS Power D3400
  • Who's Online   0 Members, 0 Anonymous, 5291 Guests (See full list)
