Xmax
vw passat
Can't answer.
Port area per foot is a rule of thumb. What you are after is TOTAL port area, which you get from tuning frequency, driver size, and power
No port area per foot is not important or as important as commonly thought.
Also snow you need the xmax also for determining port area. Power is important but it comes into play for how much power is required to achieve xmax. Box size also goes along the same lines of power. Lets say you have a 12" driver in a 1.5 cube enclosure and the same 12" driver in a 2.5 cube enclosure. The driver in the larger enclosure will achieve xmax with less power than the smaller enclosure.
Krakin's Home Dipole Project
http://www.stevemeadedesigns.com/board/topic/186153-krakins-dipole-project-new-reciever-in-rockford-science/#entry2772370
Krakin, are you some sort of mad scientist?
I would have replied earlier, but I was measuring the output of my amp with a yardstick . . .
What you hear is not the air pressure variation in itself
but what has drawn your attention
in the two streams of superimposed air pressure variations at your eardrums
An acoustic event has dimensions of Time, Tone, Loudness and Space
Everyone learns to render the 3-dimensional localization of sound based on the individual shape of their ears,
thus no formula can achieve a definite effect for every listener.
Xmax =/= total driver displacement. Suspension and other mechanical limitations have more of an effect on the required port area than just the raw xmax.
Example being a sundown X series sub. Xmax is in the 30mm range, like most other high end drivers. Due to the large surround, it even Hass less cone area than most similarly sized drivers. But yet it is a sub that really needs a lot if port. Not because of xmax, but because of how much air it can displace. Xmech is more effective than xmax when trying to figure out an enclosure IMO
And to OP: If you haven't picked up on this by now, there is no cut and dry answer. Wish I could give it to you but there is none. The port area per cubic foot rule of thumb is because of all this. It's easier for the new folks to wrap their head around. Think of it like an average, not an actual rule to follow. Something so you don't have someone building their first 2 10s box with a single 2" pvx pipe as a port
Do you know of an effective way of finding the xmech of a woofer? I would just like to know and I haven't done any searching on that yet. I can see that being much more useful especially from my knowledge Xmax, along with it being mechanically dangerous, the output is measured at 10% distortion.
This is why power does not really matter.
Cone area, Xmax, and tuning frequency are the main variables, unless you can actually model the driver in the enclosure to determine it will not reach Xmax based on the enclosure and power applied. But if you limit port area in this case, what happens when you decide to buy more power?
Current system:
1997 Blazer - (4) Customer Fi NEO subs with (8) American Bass Elite 2800.1s
Previous systems:
2000 Suburban - (4) BTL 15's and (4) IA 40.1's = 157.7 dB at 37 Hz.
1992 Astro Van - (6) BTL 15's and (6) IA 40.1's = 159.7 dB at 43 Hz.
im kinda surprised port per foot isnt as important..... cause isnt it how much port area there is just broken down by how many cubic feet the box is? I feel like if you go buy recommended specs in box size it needs x amount of port area, therefore port per foot having a big role in how it sounds, maybe im just pulling this out my ass?
2006 Ford Explorer
2 Team AA/Sundown 15s
6th order
Ct Sounds 7k
4 PRV Mr500 8s
Rockford p1000-2
Team Subsonic Lows
Port area is based on air velocity. Air velocity is based on volume swept by the sub and the frequency the port is tuned to.
I have used these 2 examples many times:
If 18" A has 6mm of Xmax and will handle 100 watts and 18" B has 30mm of Xmax and handles 4000 watts, they will not REQUIRE the same amount of port area even if the box is the same size (they can have the same amount, it is just not required on the sub that will not be pushing as much air).
Or you can look at it like this - if I put a sub in 4 cuft and power it to Xmax, or I put the same sub in 8 cuft and power it to Xmax, it will require the same amount of port area. No reason for the small box to not need as much port area.
Current system:
Previous systems:
  • Who's Online   1 Member, 0 Anonymous, 1435 Guests (See full list)
