wiring LEDs up
Got 2 24" strips that I want to wire to work with the dome light for under dash lighting. How would I go about wiring these? Work with dome.
My SPL to SQ Build Log
Vehicle:
1997 Dodge Dakota Ext Cab 4x4 2009 Dodge Journey SXT
5.2L V8 Magnum 3.5L V6
Stock Alt
Equipment:
Headunit- Alpine CDE-147BT
Mids/Highs Amp- JL Audio G6600 Class AB 6 Channel
Sub Amp- Hifonics BRZ1700.1D @ 2 Ohms Taramps DSP3000.1D
Sub- Hertz Hi Energy 12" HX300D SounDrive SDA3 12
Tweeters- Rockford Fosgate Power Series Silk Domes Hertz Hi-Energy
Mids- Dayton Audio Reference 4" Full Range Drivers
Midbass- Silver Flute 6.5" Hertz Hi-Energy 6.5"
Processor- MiniDSP 2x4
RCA- 6 channels of SounDrive HF series
Wire- EB Flex 2/0
-Member of Team SounDrive
I had just extended the wire from the led location and tapped them into the connections inside the dome light. Wasn't too tough, just take the wire straight up the a pillars,under the headliner into the dome light, find the + and -, wire it up and I was good to go.
Is it possible just to tap right into the wires running up the pillar? Tons of ruun behind to tap into them.
Vehicle:
Stock Alt
Equipment:
Wire- EB Flex 2/0
It should be possible. That was just my preference when it came to running them, tapping them right into the source. You should be fine as long as you've got the right wires.
Vehicle:
Stock Alt
Equipment:
Wire- EB Flex 2/0
Dbl post. But alright. Thanks very much. :)
Vehicle:
Stock Alt
Equipment:
Wire- EB Flex 2/0
Ok problems...
Dome and lights won't turn on. Not getting any power. Replaced the iod fuse and all other fuses seem good. Radio still works.
I'm lost so please help me. Lights work hooked to a 9v battery. But door and force on don't turn them on. I'm at a loss right now.
Vehicle:
Stock Alt
Equipment:
Wire- EB Flex 2/0
Like nothing works. I'm not getting power from the fuse box. I replaced the iod fuse but the radio works. No domes still.
Checked w a 9v before I wired them up.
Could I just have to much wired up?
Vehicle:
Stock Alt
Equipment:
Wire- EB Flex 2/0
