Sorry if this has been beaten to death over and over. No straight answers have come my way.
1 sub or 2
I have a 2001 ford escort zx2. Small trunk and cabin.
My current setup consists of: Stock alternator, Stock battery with Deep cycle in the trunk. I have the big 3 done with 0 gauge wire.
Sub: 1 SA D2 12
Box: 2ft^3 L port tuned to 35 htz
Amp: Audiopipe APSM 1500d(gains set correctly)
Wired to 1ohm
How much would i gain from adding a second identical amp, second identical sub, and second identical box?
OR which would be better adding the second identical setup or changing entire setup to....
Sub: 1 Sundown x-15 d2
Box: 3.5ft^3 L port tuned to 30 htz
Amp: Something 3000 rms maybe(crunch gp 3000 pro) definately turned down, gains set properly
Wired to 1ohm
250 amp alternator upgrade
Also, I'm looking for SPL, I listen to rap music.
Truth about the 1 vs 2
Opinions on the x-15 setup
Thank You
I'd go for one box with a common chamber for both.
Tune to your liking. Between 32-36hz probably.
145.9@40hz
145.3@34hz
big 3
X2 group 34
Deka Group 31
All 0/1 awg jl meta wire
Alpine CDA 7894
Orion HCCA D5000
2 AQ HDC312's
Crunch gpv1100.2 (for 6.5"s only)
AQ pro audio 6.5" - 3 sets
AQ supertweeters - 2 sets
2000 Slamry
Shared chamber box tuned to whatever you want. As far as an amp there are plenty of good quality amps out there...and audiopipe is NOT one of them. If you are on a budget, look into soundquebed/audioque...good amps and pretty affordable.
To make an enclosure for 2 subs just double the internal NET volume of one sub.
For an amp there are plenty of Vendors on here with reliable amps that do advertised power.
Krakin's Home Dipole Project
the 2 sa 12s would be louder than the x-15? same amp for either setup(not the audiopipe). also i would need a .5 stable daily amp, what amp?
There are many many more variable than will X be louder than Y.
The two SA's come to 1,200 RMS and the X is 1,250 RMS so They will take about the same power.
The SA's may have a little more cone area than the X.
The list goes on forever back and forth. The main thing it will boil down to is how you design your enclosure and run them from an amp with the electrical to back it up.
  • Who's Online   1 Member, 0 Anonymous, 1611 Guests (See full list)
