DC Sound Lab
16" H x 20.5" W x 19.5" D
2.20 Cu Ft Air Space
tuned @ 32hz
How does this sound for my DC XL 12" that should be arriving on monday or tuesday? I am about to start work on it tomorrow so any immediate input would be most excellent!
Current System
Deck:
Pioneer DEH-80PRS (3-WAY ACTIVE)
Incriminator Audio 3.4 4 Channel (75x4 @4 ohm)
(2) NVX X-Series Active Tweeters
(2) SB Acoustics SB16PFC25-8 6" 8 ohm Paper Cone Woofers
Subs:
(2) Sundown Audio SA-12's
Amp:
(1) Kicker CX 1800.l (43CXA1800.1) 2016 Model
(It is rated 1800 @2 ohm but I have it running at 1 ohm, does a little over 2500!)
Big 3 w/ 1/0 gauge wire
(1) XS Power D4800 under the hood
(1) Duracell Group 31 Deep Cycle
(4) Runs of KnuKonceptz Kolossus Fleks Kable (2 pos, 2 neg)
(1) KONfused 4-way Power and Ground Block
Alternator:
DC Power XP 270 High Output
i dont know if your 2.2 is gross or net but if net its too big. Theres not enough info in the box description to tell for sure
DC AUDIO
Phone Number
1(855)SPL-DBZZ
Built by Competitors, for Competitors.
  • 3 weeks later...
would an XL 12 perform better with a bigger or smaller box if being given over rated power? i'm assuming bigger would be better?
also i always hear that 12-15 inches of cross sectional port area per square foot is ideal for a ported box, but what factors would determine whether you would want more or less port area? how would you know if you want 12 of 15?
  • Who's Online   0 Members, 0 Anonymous, 2136 Guests (See full list)
