Wheel Adapter Yay or Nay?
I found some rims I really like but they are not the same bolt pattern as mine. I found some adapters that convert my bolt pattern to the wheel that I want.
I really need to know what to watch out for with these on my car.
How do I tell a good one from a bad one?
What geometry do I need to know for proper fitment?
Are these suitable for daily driving?
How much am I looking at spending?
Other things I may be overlooking?
-Matt
2005 Dodge Magnum RT
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
Audio Legion 3500.1D
2 RE MT 18s
360 ah LiFePO4 Battery
SHCA 2/0
155.2 @ 29 hz
Kicker CVR 15's build
DD 3512e build
Mini T-Line Build
(6) 8s Build
Nightshade 15s Wall Build
Magnum AB XFL 12s Build
Newest Magnum Build
http://adaptitusa.com/5x450to5x500wheeladapter.aspx
those are the ones I found that are the correct size
-Matt
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
2 RE MT 18s
SHCA 2/0
155.2 @ 29 hz
DD 3512e build
Mini T-Line Build
(6) 8s Build
Newest Magnum Build
As long as you use billet adapters, you're safe for normal driving(granny driving; won't handle wreckless driving for long). If you're going to be seeing potholes, tight turns, anything that is rougher than smooth driving; you will need steel or iron adapters. Stay away from cast aluminum adapters, we only use them for mockup purposes; we always go and get them copied out of steel when we find the look we want.
Sponsored by:
Kenwood
Pioneer
Linear Power
YWS
LoCrew Customs
AirRide
SMC
Viair
Series-tuned 6th on 4.8kw @8ohms.
Hubcentric ks different than a bolt pattern adapter. It scares me to run adapters especially if you cNt get the right offset to mske the wheels sit right
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
I think I am leaning away from adapters at this point. I just need to save and get some wheels that fit
-Matt
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
2 RE MT 18s
SHCA 2/0
155.2 @ 29 hz
DD 3512e build
Mini T-Line Build
(6) 8s Build
Newest Magnum Build
I hated mine, don't like him. Buy wheels that fit your car. I wasn't happy until I did anyways. Most of the time they stick your wheels out of fender wheels . Then rock hit your paint because of it. For me my wheels never felt balanced . Got wheels that fit and couldn't be happier doing so. But it works out for some. But didn't for me.
