Sergeant_Skyrim Posted September 17, 2013 Report Posted September 17, 2013 EDIT: Got the info I was looking for thanks for the help everybody. Dead thread now Legitimate question here, would running a 2k watt amp at 1 ohm have the same voltage drop as a bigger amp that puts out 2k at 4 ohms? Let's assume here: 1. Same exact amp for all practical purposes. Not brand A is cheaper than brand B so of course B would be better. 2. They're actually doing 2k each at their respective ohm loads. No specific brands or amps as of right now, more interested in a technical answer at the moment. Didn't really know if this should go in the amp or the electrical section but since I'm not naming brands I've decided to put it here. Any insight is much appreciated as always! Build in progress
SnowDrifter Posted September 17, 2013 Report Posted September 17, 2013 4 ohm would, in theory, be more efficient since the various conductors would be carrying less amperage. But realistically they are the same. ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444
thefourth Posted September 17, 2013 Report Posted September 17, 2013 4 ohm would, in theory, be more efficient since the various conductors would be carrying less amperage. But realistically they are the same. Perfect answer. Thanks alaskanzx5 I might just do thatI can recone a sub myself. About a year ago I took 2 12" power acoustic mofos and made one sub. I took the magnet and the motor off of one and j b welded it to the other motor and magnet. I had to wind my own voice coil so it would work. After I was done hooked up to 2 boss 5000w amps. And shattered my back and all my side windows came to this thread to recommend soundqubed and ct sounds. OP goes with soundstream. oh lawd.
CleanSierra Posted September 17, 2013 Report Posted September 17, 2013 I would think efficiency rating and quality of parts in the amp itself would determine the voltage drop dilemma as well. If amp A is putting out 2K @ 1 ohm and is 72% efficient doing it vs. amp B making 2K @ 4 ohms while being 82% efficient, the amp making its power at the higher efficiency should, in theory as Snow said, have the less voltage drop. Im not the one you want to try to troll. Just a fyi for you.
97Jetta1637 Posted September 17, 2013 Report Posted September 17, 2013 probably be a hell of a lot cleaner too seeing how that's how sq guys normally do it. globs of power, but at 4 ohms. #teamihop Two 12 inch DC XL's Carbon Fiber Cap Stetsom 7k Shell of box / baffle built by me Port / sealing the box by John Hone Fuck midrange Alpine-9886 http://www.stevemeadedesigns.com/board/topic/177428-97jettas-sql-trunk-wall-loudest-99-buick-century-custom-with-a-one-legged-owner/ price has no influence on how something sounds I told him to move the fucking port. they see me hoppin they stoppin they can't believe im so white and dirty It looks like you got so drunk, that someone came up and stole your leg.
AMI CUSTOMS Posted September 17, 2013 Report Posted September 17, 2013 Higher ohm load is always better if you can swing it, but most people want big power for cheap so they run at like .25 or some shit TEAM SOUNDQUBED -- TEAM SOUTH TEAM S.O.B. - Founder & Captain 3x Streetbeat World Record Holder 2017 MWSPL 1st place Mayhem & 4th Xtreme 4 2016 MWSPL 1st place Mayhem/2nd Adv 4/2nd Xtreme 4 2015 MWSPL 2nd place Mayhem & 4th Xtreme 4 2014 USACI 2nd place Streetbeat 5 - 162.6 db 2014 MWSPL 2nd place Xtreme 4 - 144.9 db 2013 USACI 1st place Streetbeat 4 - 161.9 db 2013 USACI 1st place Street Q+ - 162.8 db 2013 MWSPL 3rd Kaos2 & 4th Xtreme 4 2011 USACI 2nd place MOD 1001-2k - 160.0 db 2011 MWSPL 4th place: Adv3 - 157.8 db, Kaos2 - 150s db, Xtreme4 - 140s db 2010 ARSPL 1st place 501-750 - 160.3 db Arkansas loudest Best score to date 164.4 db - Termlab Outlaw Streetbeat 4 - 161.9 db Streetbeat 5 - 162.6 db MWSPL on Dash Legal door open (Music) - 162.5 db Sealed on dash Legal (Music) - 161.1 db - Termlab THE BLACK NASTY CURRENT BUILD & FAB The Black Nasty (6) 15 Rebuild Log 2012 (4) 15 Walled Sierra Build Log Evo X build log Facebook page The Black Nasty
SnowDrifter Posted September 17, 2013 Report Posted September 17, 2013 probably be a hell of a lot cleaner too seeing how that's how sq guys normally do it. globs of power, but at 4 ohms. Don't the SQ guys do it at 4 ohms because they use a/b amps vs class D amps? Plus higher damping factor? ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444
David Bailey Posted September 17, 2013 Report Posted September 17, 2013 Ahhh, so running mids and highs at a 4ohm load would sound better and cleaner, but leave the one ohm for the lows since it is not nearly as noticeable as highs. I just learned something. Did you get that scar tissue when you got your vagina installed? KNOWLEDGE DESTROYS FEAR Measure twice, cut once JVC touchscreen HU Mmats E600.4 Realm L56c Audiophile 6.5 comps up front JBL P963 rear deck PB RTA 112 trunk CE Auto Big 3 Mechman 240alt D'Amore VM-1
97Jetta1637 Posted September 17, 2013 Report Posted September 17, 2013 probably be a hell of a lot cleaner too seeing how that's how sq guys normally do it. globs of power, but at 4 ohms. Don't the SQ guys do it at 4 ohms because they use a/b amps vs class D amps? Plus higher damping factor? no idea, not an sq guy. i just know it's primarily higher ohm loads from the sq guys i've talked too. #teamihop Two 12 inch DC XL's Carbon Fiber Cap Stetsom 7k Shell of box / baffle built by me Port / sealing the box by John Hone Fuck midrange Alpine-9886 http://www.stevemeadedesigns.com/board/topic/177428-97jettas-sql-trunk-wall-loudest-99-buick-century-custom-with-a-one-legged-owner/ price has no influence on how something sounds I told him to move the fucking port. they see me hoppin they stoppin they can't believe im so white and dirty It looks like you got so drunk, that someone came up and stole your leg.
Sergeant_Skyrim Posted September 17, 2013 Author Report Posted September 17, 2013 Thanks for the insight guys. Only asked because I'm going to play around with a few different setups while I wait to buy a new HO alt that'll charge at idle. So was planning on either doing my BRX2000 @ 1 or my DC 9k @ 4 on stock alt with the XP3000 in there. Not going crazy or anything, but just using them to get some hands-on experience making some different types of enclosures and that fun stuff Build in progress
