Belt questions for HO Alt
So my factory, 18 year old alt is finally starting to die.. and I have plans on going bigger *cough* DC 5K and XLs.. so Im ordering a Singer 230A Alt.
Online, it says that the factory belt is 45.49 inches. Ive been reading to get a .5" shorter belt.. So should I look at a 45" long belt?
Does it matter that the Singer alt has an overdrive pulley, when choosing belt length?
There are many options for how many ribs I want the belt to have. What is recommended?
What brands are recommended? I remember hearing something about Gates Green Belts a while ago. Are they still preferred?
One last question.. my car doesnt set the belt tension automatically.. how tight should it be?
Thanks in advance guys B)
LMFAO so true
:blush:
Mitsubishi 3000GT (Old Build)
Headunit: Pioneer 80PRS
2005 Chevy Colorado Ext Cab
My Official Feedback Thread
for ribs, use whatever amount the pullies on your car have been designed for. my corolla was like 4 ribs or something.
you dont want 1 less rib, but you dont want 1 bigger either. 1 less and you're wasting potential pulley grip. 1 more and you might tear the belt, or the edge of it thats hanging off all the pulleys.
edit: my corolla had a manual tension system. i just tightened it til i had like a half inch or so of play in the middle of the longest open stretch of belt (between two pullies or whatever). but then after like a month or so i would have to re-tighten it because of dat squeel, then it was fine after that i believe.
Gates...
he wouldnt be the first to say they did a 167 with a system like that (one that clearly DOESNT), but i have to say, he didnt beat me anywhere, ive never competed against the guy. If he thinks his does a 167, mine would probably put him in a coma. :hairtrick:
Cool.. Thanks Stelio.. I didnt understand how important the ribs were. As of right now, I guess I should plan to tighten until theres just under 1/2" of play.
Anyone else?
LMFAO so true
:blush:
Most important thing is a good belt. I would use a gates green stripe or a Goodyear gator back. That's all I used to run on my supercharged thunderbird it would destroy any other belt in less than a month
Alright, so Im looking at Gates' website for Green Stripes.. and came across different belts. Do I get the "Green Stripe Micro-V Belt?"
LMFAO so true
:blush:
O'reillys carries gates belts....check with them first, if you can get it local its easier if you need to return it and get a different size
Good looks :friends:
LMFAO so true
:blush:
  • Who's Online   0 Members, 0 Anonymous, 2118 Guests (See full list)
