squeking
I changed alternator serpentine belt and idler pulley as well as tensioner. And I still get squeaking it gets louder every time I step on gas. Belt is tight it has been doing thing even before I got another alternator. I used a soap bar against belt it stops squeaking for a couple hours. I have a 02 silverado 1500 v8 Can any one help me with this problem
<p>Pioneer AVIC 6000 NEX, JBL 660c Components - FI SP415- Arc audio xdi2000.1- Xs Power- 0 gauge, Big 3 Upgrade Dc Power xp270
Any 1
Try shorter belt?.
CURRENT SYSTEM:
  • Alternator:
    1. Stock alt on mids/highs
  • Batteries: (2) XS D1400s
  • Headunit: 80-PRS
  • Sub Amp: DC 5.0k
  • Mids & Highs Amp: CT125.4
  • Active Components:
    • Mids RE XXX 6.5c
Build Log
Highest Legal Score: 151.0 db
I'm going to get a half inch shorter. When I pulled the tentioner tighter with a wrench the squeaking stop so on my way to get smaller belt see how it does
it could be the tentioner wheel when mine gets wet it does it all day
02 dodge ram 1500 reg cab 3rd gen
2 sundown sd-2 d4
soundstream rub1.2500 amp
all sky high car audio-fuse,fuse holder,wire,ring lugs and rca
flex tech
box design by Joe X
supension-mcgaughys 2in drop spindal ,western chassis 6in flip kit,buddy custom c-notch
04 5.7l hemi motor swap and made it an slt eletric everthing
youtube channel-http://www.youtube.c...43?feature=mhee
http://www.stevemeadedesigns.com/board/topic/190882-02-dodge-ram-1500-3rd-gen/
Like a whheeeeeeeeeee
I had got a new tentioner still when I would rev the sound just got stronger
did it ever stop with new belt, if it still does it could be the alt.like I said when mine gets wet it whheeeeeeeeeee all day but when I hit 50mph it stops then when I slow down it does it again but you said you but a new one.
2 sundown sd-2 d4
flex tech
box design by Joe X
  • Who's Online   0 Members, 0 Anonymous, 1422 Guests (See full list)
