RED ALERT F'd up a amp need help
So i have a old american bass amp that i decided not to use right not. So im taking it out of the car and on the remote wire set screw broke off in the hole Any tips for getting it out.
It was all my fault my dumb ass put a drop of thread lock on the set screw because it vibrated loose a few times( yes i know i will get all types of bad comments). Haven't had time to deal with it had to go to work.
Please take it easy on me. SMH lol.
I realy like this amp its a nice solid amp that i brought used for $40 bucks.
2009 bmw 5 series
Head Unit Stock
Amplifier-JL Audio JX 360/4
Processor- Audiocontrol LC6
really small easy out should do it. If not drill it out and tap the next size up.
CURRENT SYSTEM:
  • Alternator:
    1. Stock alt on mids/highs
  • Batteries: (2) XS D1400s
  • Headunit: 80-PRS
  • Sub Amp: DC 5.0k
  • Mids & Highs Amp: CT125.4
  • Active Components:
    • Mids RE XXX 6.5c
Build Log
Highest Legal Score: 151.0 db
i don't think drilling is a option because it did not break flat.
2009 bmw 5 series
Head Unit Stock
is all hope lost?
2009 bmw 5 series
Head Unit Stock
have a dremel could try making a notch in it to use a flat blade. werew theres a will theres a way could drill it out just carefully
i have a dremel but what would fit in there to make a notch?
i'm going to sears in the a.m. to get a small drill bit for steel.
2009 bmw 5 series
Head Unit Stock
What type of thread lock did you use?
lol RED
2009 bmw 5 series
Head Unit Stock
lol RED
That's not good red is meant to be permanent it's gonna be tough getting that out. Good look hopefully it works out for you
