RED ALERT F'd up a amp need help
well ain't that a bitch.
2009 bmw 5 series
Head Unit Stock
Amplifier-JL Audio JX 360/4
Processor- Audiocontrol LC6
Yep. If I remember right they say it takes 400 degree heat to break red thread lock free. I've actually had to heat bolts till red hot to break them free with the red.
Drilling out should work though but you might have to go a hair bigger than the screw and tap some new threads.
i lucked out wonce and did it with a soldering iron i held it on the screw for 25mins and all of a sudden threds caught fire as red loctite burnt away i used it a couple times on my rc's
now i know to stick to blue
What is film it out,what does that mean. i may try the drill bit method. and the soldiering gun method.
2009 bmw 5 series
Head Unit Stock
i think i can drill the front out melt some soldier put some 8 gauge in there and pour the melted soldier in there.
2009 bmw 5 series
Head Unit Stock
If you can't get it out, I would just drill a hole in the set screw (through the side/input part) like posted above and leave a 6 inch piece of wire sticking out (like a direct lead) and connect your remote turn on to that. Not the pretiest option, but you paid $40 for the amp, it will work, and it is just a remote turn on wire. Seems like a win if all else fails.
An easy out might get it out, but it might not be able to break your thread lock. I would try that first.
2006 Scion xB
2 Sundown SA12D2
Ported at 32hz
147 on non termlab (140-142 on TL)
Currently in a walled 4th @ 50hz (not metered yet)
Hifonics brz2100
Alpine Type-S Components
Kicker 300.2
Big 3 / Skyhigh 1/0 cca
Optima Blue Top
3 e8s ported at 32hz
135.1 sealed on dash @ 56hz
135.0 outlaw (I must have chosen song poorly lol)
Build log
'Brandon15zzz', on 09 May 2012 - 3:13 PM, said:snapback.png
May have been clipping but none fucks were givin.
i think thats the best option i have to pick up a fresh drill bit.
2009 bmw 5 series
Head Unit Stock
i drilled it out best i could then i melted some soldier- stuck the wire in the hole then poured the soldier in there.
2009 bmw 5 series
Head Unit Stock
