Chance_P Posted September 23, 2013 Report Posted September 23, 2013 My jeep has a factory 117a alternator. Denso externally regulated small case. I can buy a bolt in large case denso 160 amp for 50 bucks. Anyone think its worth it? Its not a rebuilt alt, just a factory denso alternator with half the miles my 117a has on it. The 160 has a larger pulley so I will swap the smaller one from my 117a onto it. Ive got plenty of belt wrap to prevent slippage. Im running a hifonics zrx2000 and a soundstream picasso nano 520.4. Does this sound like a good idea or a waste of effort?
SnowDrifter Posted September 23, 2013 Report Posted September 23, 2013 Shoot for 50 bucks might as well give it a try. Just save your original stock alt. ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444
graham0599 Posted September 23, 2013 Report Posted September 23, 2013 It can't hurt to do. Especially at that price. How much voltage drop do you have currently though? My 350z build- http://www.stevemeadedesigns.com/board/topic/174424-2008-350z-build/page-2?hl=%2B350z+%2Bbuild#entry2605678
HHR Ed Posted September 23, 2013 Report Posted September 23, 2013 Sure its worth it. Can always use a bit of extra power at only $50 Ed Lester ShowtimeSPL Host Showtime Electronics Video MarketingMy old Build Loghttp://www.stevemead...08/#entry511451http://www.youtube.com/showtimespl 5 time dB Drag Finalist Last ride 2007 HHR, current dB 153.5 and bass race 149.4 dB. 153.0 dB on music New Ride, 2008 HHR SS. Build under way. Loudest score ever = 171dB 2009 dB Drag Racing, North American Points Champion
Chance_P Posted September 23, 2013 Author Report Posted September 23, 2013 Voltage drop is pretty bad after I removed my second battery. Probably down to 13.0 while driving. I have a cheap battery up front but im replacing it with a rebadged deka intimidator from oriellys on friday.
graham0599 Posted September 23, 2013 Report Posted September 23, 2013 Then I would do the alt. Also do the big 3 if you haven't already My 350z build- http://www.stevemeadedesigns.com/board/topic/174424-2008-350z-build/page-2?hl=%2B350z+%2Bbuild#entry2605678
Chance_P Posted September 23, 2013 Author Report Posted September 23, 2013 Big 3 is done. Ill pick up the alt and post up some before and after voltage readings. Thanks guys.
ChevyBoy95 Posted September 23, 2013 Report Posted September 23, 2013 for 50 bucks i would do it asap. go to DC, Mech, or any alt compenies we use and it will be like 300 bucks for a 160 Best Score to Date : 160.5 dB Outlaw (47Hz)[4 XM 15's & 2 Taramps Bass 12k's] BL : http://www.stevemeadedesigns.com/board/topic/147800-chevyboy95s-4-15s-7krms-wall-1533-db-on-half-power/YouTube: http://www.youtube.com/hitemwiththeflex/
Chance_P Posted September 24, 2013 Author Report Posted September 24, 2013 I wish I could have gotten some before and after readings but my multimeter decided it wanted to commit suicide. Ive never felt wires get so hot lol. Pretty sure it has to do with my friend using it to test current draw the other day.. but anyways. I can't believe the difference installing that alt made. Zero voltage drop while driving and my volt gauge (factory innacurate pos) doesnt drop below 13v at 700rpm idle with headlights on. It used to hit 11.8-12 with my lights off. My system really woke up also. I thought I was getting used to everything because it was a bit quieter but now its back to what it used to be. Can't wait to get some numbers at the midwest spl event this saturday! It'll be my first time at an event.
Chance_P Posted September 24, 2013 Author Report Posted September 24, 2013 Pretty sure my factory alt was on its last leg. My Jeep fires up so much faster now which I found odd. I've got to install an anl fuse tomorrow because I lost my fuseable link between the alt and pdc when I did my big three with 2/0. I normally fuse to what the wire can handle but since its just from the alt to the pdc and my alt is only 160, should I just stick a 200amp fuse in there to be on the safe side?
