rockford 1200.1D is melting wires.
whatusay45
Do a battery ground, engine block to ground, alt to ground, Alt to battery +, then run your 1/0 to rear battery. Then do a rear 1/0 ground to strut tower or frame, largest thickest metal you can find. Then maybe look into some 1/0 to 4ga reducers for your amps, maybe overkill for now, but it will be worth it down the road.
Jeep Cherokee 4dr -4.75 in front, new rusty's 4.5 in rear leafs -micky thompson 35x14.50x15 -locker rear -Rusty's offroad Engine/transmission/transfer case/crossmember/gas tank skid plates -Warn front bumper with 8000lb winch -Custom rear bumper -Warrior product tube doors (summertime) -Optima redtop (starter) -26XK miles and still runs like a bat out of hell
Kenwood H/U
1/0 wire,
136 amp alt 200 ah batteries 12.7 daily
2 Apsm 1500 @ 2 ohm strapped on zv3 d1 with ns softparts
Mb quart 125.4 wired to 4 aura 6's
3.6 cube box tuned to 36 plays down to 23hz
sweet thanks but i think the rsx has a battery ground engine ground alt ground and one other.. i was like WTF when i read it on another forum.. and its hard to get to the alternator unless u have a lift..
Even if it has the grounds there from the factory you should still upgrade them, unless you were saying it just has spots to ground at.
02 Dodge Durango
1 Fi SP4 18" .v2
Sundown SCV3k @.5 Ohms
XS D3100 up front
Northstar SMS AGM 400 in the back
All XS Power 0ga OFC
240a Apex h/o alternator
Pioneer AVH-X2500BT HU
Dual 0ga runs from the alt to battery
Dual 0ga runs from battery to amp
KnuKoncept makes good fuse blocks but you have to know how to install the wire the right way in them. I run there battery terminals and you need to be good at installing the wire into the compression fitting. Been running them for over a year no issues at all.
Ill disagree with this. The compression fittings suck ass. terrible idea.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
  • Who's Online   1 Member, 0 Anonymous, 1014 Guests (See full list)
