Do tires really add a difference in ride?
More rubber = softer ride... Low pro 45's and you feel every bumb in the road, bigger (standard) tire and the rubber/air absorbs the bumps. I think the difference in name/price will show more in handling and wear, but not feel.
I'm running nexen 275/40/17 also have a 3/4 drop and it rides good until the rear end hits the bumper stops but that will be fixed when a 4in c-notch but other then that it rides good
I'm not saying they won't ride good (low pros), just gonna feel more bumps than a standard tire. That's why folks like us slow down for manhole covers and train tracks ;)
shit I don't even with the low and lower kit it still rides smooth until the rear end hits the bump stops
02 dodge ram 1500 reg cab 3rd gen
2 sundown sd-2 d4
soundstream rub1.2500 amp
all sky high car audio-fuse,fuse holder,wire,ring lugs and rca
flex tech
box design by Joe X
supension-mcgaughys 2in drop spindal ,western chassis 6in flip kit,buddy custom c-notch
04 5.7l hemi motor swap and made it an slt eletric everthing
youtube channel-http://www.youtube.c...43?feature=mhee
http://www.stevemeadedesigns.com/board/topic/190882-02-dodge-ram-1500-3rd-gen/
Tires will most certainly influence ride quality... Some ride better than others and different compounds will have different impacts etc...
Honestly tires are not a place to cheap out if you can afford to go with quality set then do it
Team MaxRetribution
Si Vis Pacem Parabellum
What's a quality set? I always bought either used or just the oem replacement. But now that I spent 2 racks on rims I want some quality tires.
Toyo Open Country M/T. 37/12.5/22. Never slip and slide in the rain again. Also, you'll look fucking beast.
Yes tires make a huge difference.
When I ran yokahama's because the Nitto's I wanted weren't in stock. Steering and control felt sloppy. Went back to the Nitto's and everything felt tight and in control again.
on my Z, I tried dunlops instead of potenza's and it feels like the car has a lot more under steer.
Just like stereo's, I can't tell you what are tires good. you may like what I call a sloppy ride with too much tire roll.
  • Who's Online   0 Members, 0 Anonymous, 1035 Guests (See full list)
